Software & pulley upgrade.......
Old Apr 5, 2024 | 03:22 PM
Turko's Avatar
Default Software & pulley upgrade.......
This video is worth watching.
Paramount/VIEZU is a solid company. You get to see them in action.
Old Apr 6, 2024 | 03:28 PM
Craaaazzy's Avatar
I like that they covered the seat as well as the steering wheel, very professional.
Old Apr 6, 2024 | 03:41 PM
jcb-memphis's Avatar
Been utterly satisfied with VAP. Tuning these cars is wonderful - the v6 on e85 is 550hp.... 475 on 93. That is remarkable...and the zf8hp70 in the F-type is in no way overwhelmed by these numbers out of a tuned v6. I worry about a tuned v8...
Via google search:
The ZF8HP70 transmission has a torque handling limit of 700 N⋅m (520 lbf⋅ft). The 70 in the 8HP refers to 700nm or around 516 ft lbs.
Old Apr 7, 2024 | 06:17 AM
bfrank1972's Avatar
Via google search:
I'm sure the VAP folks have done their research but we will see. Bunch of tuned v8's have been out for a while, I haven't heard of any issues, but I guess we will see! Tuned life 650+ hp (on pump) is a real hoot!
Old Apr 7, 2024 | 09:42 AM
I think the "YouTube" limit on the zf8hp70 is like 700 ft lbs (have no idea, so don't quote me)...the quote I used was the factory limit which ironically is just over the stock SVR/R.2.....likely on purpose.
Old Apr 7, 2024 | 10:11 AM
bfrank1972's Avatar
Yeah, hard to say, need empirical evidence to really know, and even then it has to do with how the torque is applied (how you drive the car, rwd vs awd, how you maintain, etc). It's just like your motor was not factory engineered to produce 475 hp, but companies like VAP do extensive work to determine what we all can get away with "safely". Modding always has a degree of risk because we are eating away at the large safety margine manufacturers engineer in (some systems have more margin than others). Probably the same with the ZF, but again I have no idea other than the fact my transmission shifts hard wide open and has given me no issue. Like my motor oil, I plan to change the transmission fluid at an increased frequency. That ZF is used in other cars where you probably could read on how they fare on modified cars (I think Dodge uses them and there's a fairly large community of modders)
Old Apr 7, 2024 | 11:42 AM
scm's Avatar
scm
According the numbers in my MY18 handbook, the 550 engine is 680Nm and the 575 is 700Nm, so right on the limit.
Old Apr 7, 2024 | 06:51 PM
OzXFR's Avatar
I suspect the quoted 700 Nm is a little under what it is really putting out so as to seem to comply with the ZF 8HP70 limit.
I believe the 700 Nm figure for the gearbox is also very conservative and it can easily and safely handle quite a bit more.
Lastly the TCU and PCM talk to each other so as to wind back/limit engine torque if the TCU detects conditions where full torque might be a strain on the gearbox.
My old 2010 XFS (3.0 litre V6 twin turbo diesel with the older 6HP26) was tuned for over 700 Nm, it went like a scalded cat and I never once had any gearbox problems.
Kyle_rs
Jun 15, 2023 12:12 PM
Terry007
Dec 31, 2021 03:48 PM
MuttonJohn
Jun 14, 2021 04:30 PM
benfbrown
Mar 10, 2020 09:48 PM
