Upper & Lower Pulley on a 5.0
Old Jun 12, 2023 | 05:04 AM
Kyle_rs's Avatar
Default Upper & Lower Pulley on a 5.0
Quick one here, I've already got the 7.5% reduction upper pulley from powerhouse and a tune, the Eurotoys lower pulley is arriving this week and I'll get a tune for both, I've done a fair bit of reading up on this and I'm convinced I'm not gonna need the Charge cooler upgrade living in Ireland where the average yearly temp is 10c and summer Max is 25c (for about 2 days) Thoughts on this?
Is there anyone with over 600hp on a 5.0 not running the upgraded Charge Cooler?
Cheers chaps.
Old Jun 12, 2023 | 07:19 PM
u102768's Avatar
I did fit a higher flow S/C coolant pump but haven't touch any radiators.
Old Jun 12, 2023 | 08:26 PM
jahummer's Avatar
An uprated charge cooler's going to make a difference with heat soak in very high temps, either ambient or from prolonged hard driving such as endurance racing on a track. For normal driving, even with increased power you're not likely to ever push it hard enough continuously to get it so hot that charge air becomes too hot.
Old Jun 13, 2023 | 04:20 AM
Kyle_rs's Avatar
Perfect, I've got the upgraded pump in too so we are in the same boat, have you an idea what figures you got to with the two pulleys?
Old Jun 13, 2023 | 04:21 AM
Kyle_rs's Avatar
Superb, That sounds about right to me, I'm happy to go ahead then and get the spanners out.
Cheers chum
Old Jun 13, 2023 | 07:14 PM
u102768's Avatar
I have only had the upper pulley changed so I will be interested to see how you get on with both.
Old Jun 14, 2023 | 12:42 AM
tmich's Avatar
I have both pulleys changed. ~615BHP. But they most likely can go higher. There is any issue with higher boost on my engine.
But I have bigger intercooler and zzp performance supercharger water pump (the second not yet installed).
Old Jun 14, 2023 | 04:23 AM
Kyle_rs's Avatar
If we get there, running into issues here, I'll start another thread
Old Jun 14, 2023 | 04:24 AM
Kyle_rs's Avatar
Superb result!
Old Jun 15, 2023 | 12:12 PM
Cee Jay's Avatar
I personally know a guy who used to be in this forum who did both pulleys. He stated that it lowered the performance even with a tune because the supercharger reached max output before the engine did. He said it bogged really bad on the top end, even with the best tune.
Mrseam
Mar 24, 2022 03:20 PM
hammam almulhe
Jun 30, 2021 03:33 AM
santacruz11
Apr 17, 2021 09:22 PM
F-type Rose
Feb 7, 2020 06:12 PM
Ghostiest
Apr 20, 2017 06:37 PM
