Spacer temp
Old Oct 18, 2018 | 04:39 PM
mlebofsky's Avatar
Default Spacer temp
Anyone have any idea what temps wheel spacers should be able to handle?
I have CCBs if that matters...
Old Oct 18, 2018 | 06:56 PM
OzXFR's Avatar
Wheel spacers shouldn't get anywhere near as hot as the brake rotors and pads, if they do there is something wrong.
AFAIK pretty much all spacers are made from high grade aloooooominum alloy and I have never heard of anyone having a problem with spacers getting too hot.
Old Oct 18, 2018 | 07:29 PM
Unhingd's Avatar
Lumium melts at 1221 degF. Brake accordingly.
Ceramic brakes do not heat up anymore than steel breaks. They just don’t fade as much at high temps.
Old Oct 18, 2018 | 07:36 PM
mlebofsky's Avatar
Yes to all the above.
Considering the CCBs on race day can hit 1000 degF, wondering if the spacers get anywhere near that.
I'm testing a few things ………...
Old Oct 22, 2018 | 07:21 PM
mlebofsky's Avatar
Can someone with an IR thermometer point it at your wheel spacers after some hard braking?
I assume the fronts will read hotter than the rears …..
Thanks in advance.
Old Oct 22, 2018 | 07:27 PM
SinF's Avatar
If you ever took oxy torch to it, aluminum goes very liquid very rapidly. All of it. Nothing like steel.
Old Oct 22, 2018 | 09:13 PM
lizzardo's Avatar
If an aluminum spacer would melt, so would your rim. I think you'd be burning the seals on your wheel bearings and setting fire to the grease long before that. The street luge folks call that a "flame out." It's probably more dramatic when the flaming bearings are a foot from your head.
Old Oct 23, 2018 | 11:30 AM
mlebofsky's Avatar
Thanks.
I'm not worried about things melting or vaporizing. I simply need to know how hot they get under hard braking....
Old Oct 23, 2018 | 04:25 PM
BruceTheQuail's Avatar
This is only a guess but I wouldnt have thought any hotter than the hub itself, as there is no friction on the spacer and they arent in contact with the rotor. But I was concerned when I opened the box on the H & R spacers I had ordered and it said that they arent to be used if the car is tracked - not that I track my car but I inferred that it might create some issue having them on.
Old Oct 23, 2018 | 07:49 PM
lizzardo's Avatar
I suspect that any issues from a spacer would be altered loading on the suspension, and that they're covering themselves against liability in cases of "severe service."
XJ8JR
Mar 2, 2022 10:08 AM
ianritchie
Aug 22, 2017 12:15 AM
webbeing
Apr 19, 2016 10:41 AM
Ophitoxaemia
Feb 4, 2015 11:22 PM
Jag-Nut
Mar 14, 2013 08:49 PM
