Spoiler stuck in closed position
Yes, the spoiler is stuck in the closed position. The removal options I've been directed to all start with 'Raise the Spoiler'. I can't since it is stuck in the closed/lowered position. I have checked the fuse and it is good. I have also tried pushing the button on the console. That also does not work. I get the "unavailable" message on the dash.
I've googled it with nothing showing up except removal of fixed wing spoilers on coupes. That doesn't do me any good since I have neither of those.
Does anyone know of a procedure for removal of a spoiler stuck in the closed/lowered position? Or maybe a way of physically, not electrically, raising the spoiler?
Here’s a link to the workshop manual. It has a lot of spoiler info, but I didn’t look to see if it addresses your issue. Hint: the PDF table of contents is your friend, and is very helpful for finding things, as is the PDF search function.
https://www.dropbox.com/scl/fi/o6d1x...=vt10sg14&dl=0
I have already been through that PDF trying to find some information about the spoiler. Supposedly you need to look in 501-03. I went through every page of the 501-XX and didn't see anything about it.
I was curious so I too looked around with a little googling. Yeah, not a lot of direct info popping up. You would think that there would be others out there complaining about such a dilemma, but I dont see anything either. Surely you are not the first to be in this situation.
Most Jag owners likely just take it to the dealer. You have warranty?
rscultho
Apr 12, 2012 03:24 AM
