Steering Wheel Control - Loose Wire
Old Apr 12, 2022 | 12:00 PM
CPotvin's Avatar
Default Steering Wheel Control - Loose Wire
Hi All!
New to the F-Type life, I bought a 2015 f-type base recently. I was cleaning the interior of the... sticky buttons, specifically the steering wheel buttons (cruise control and such). Later that day I went for a drive and I had several messages pop up on me:
Manual shift disabled
Cruise control disabled
ASL disabled
I have since taken the switch packs out and the right side (cruise control) board was corroded (first photo) so I cleaned it with 91% iso alcohol. The left side however had a wire not even in the connector?! Does anyone know which pin this should (appears to be 2 choices) go to or if it is meant to not be plugged in? (second photo)
Thanks!!
Old Apr 12, 2022 | 12:58 PM
clubairth1's Avatar
Community Influencer
With all those water stains (whitish stains) on the PCB I would look at getting a used set off EBay to replace them. Not sure how/why the water got to those boards either? They are not in an area that is easy to spill anything into?
Do you have the electrical diagrams for the car? I only have the XJ versions and not sure they are the same?
Old Apr 12, 2022 | 03:19 PM
CPotvin's Avatar
I think the wire goes to pin #6... it however did not help anything. Ordered the right-side steering wheel switch pack... I'll come back in a week or so when I receive it.
euphonium01
Jan 24, 2023 02:50 PM
Haytham.zidane
Oct 28, 2021 05:19 PM
Nickers
Nov 13, 2020 03:52 PM
dpappyp
Nov 18, 2015 09:51 PM
bocatrip
Feb 20, 2014 01:43 PM
