SVR 2018 oil check
Old Dec 8, 2017 | 04:11 AM
nrwatson's Avatar
Default SVR 2018 oil check
On the new SVR
When I do an oil check I only get OK
There is a level graph but this doesn’t show any levels is that normal
Old Dec 8, 2017 | 04:42 AM
dave_Sw1's Avatar
I assume you are doing it cold before you start the engine, if you mean there is no yellow blocks showing up the side of the graph then you have no oil or very low oil, I would not drive it, call Jag assist. I had a leak on my MY18 SVR through the diff casing but no oil was on the garage floor as it pooled in the under tray until the car was moving. if you are still unsure post a photo of the oil check gauge but you should have Amber/yellow bars up the side of it showing how full
Old Dec 8, 2017 | 04:45 AM
dave_Sw1's Avatar
P.S. Never come across anyone else who also has an SVR vert! good choice!
Old Dec 8, 2017 | 01:16 PM
SinF's Avatar
Can you please post a picture of this?
Old Dec 8, 2017 | 01:18 PM
SinF's Avatar
Originally Posted by dave_Sw1
you have no oil
This is one possible explanation, however no bars doesn't mean zero oil. It means that it is substantially down.
Considering that F-Type DOES NOT warn about low oil condition when driving, this issue should be taken seriously.
Old Dec 8, 2017 | 09:56 PM
ndabunka's Avatar
Originally Posted by nrwatson
On the new SVR
Normal - In order to see the ACTUAL level you need to use the process outlined in other threads here. Lift the bonnet, press ignition button without foot on pedal (provides ignition but does not actually start the engine), toggle through choices to vehicle info, toggle to oil level. Hit CAN (Cancel) on the steering wheel button TWICE and you will then be able to see the actual fluid levels
Old Dec 8, 2017 | 09:58 PM
ndabunka's Avatar
If he is simply working through the menu button using it ONLY, he will see no fluid level. No reason to think he has an leaks nor is in any way low.
Old Dec 9, 2017 | 11:25 AM
dave_Sw1's Avatar
sorry mate but think you are wrong there, when I get in and press start without the brake pressed i can scroll through and see oil level every time
Old Dec 9, 2017 | 12:32 PM
ndabunka's Avatar
I stand corrected. I had been checking after I had run the car which required those additional steps. I just checked mine that had been sitting overnight and did see that I have a yellow fluid level even without having to use the cancel function when checked cold, not started. Apologies for the unintentional misdirection
Old Dec 10, 2017 | 04:13 AM
nrwatson's Avatar
Thank you
I had run the car and then turned ignition with foot on brake then scrolled but didn’t open bonnet
Wasn’t mentioned by the dealer
Old Dec 10, 2017 | 11:39 AM
ndabunka's Avatar
Thank you
Happy to have been of assistance
Old Dec 11, 2017 | 02:33 AM
nrwatson's Avatar
Wish they still did Italian racing red
Old Dec 11, 2017 | 05:22 AM
dave_Sw1's Avatar
Guessing you had plenty of oil then did you spec yours without the rear wing or was it dealer stock one?
Old Dec 12, 2017 | 06:12 AM
nrwatson's Avatar
No got the fixed rear wing I speced car
Old Jan 8, 2018 | 07:09 AM
nrwatson's Avatar
I have rechecked my oil levels
All I get is ok there is no marker to show the actual levels
Old Jan 8, 2018 | 08:06 AM
sparky fuze's Avatar
Did you "spec" the car to come full with oil? (Sorry, I just couldn't resist. I know it's not very funny, but this electronic oil level check method is simply ridiculous on such an expensive car.)
Best to take it into a dealer and have them check the level to be absolutely sure.
Old Jan 8, 2018 | 05:31 PM
OzXFR's Avatar
It seems the only way to be absolutely sure of the oil level is to drain it all out and measure what comes out, and I guess a dealer would charge a packet to do this plus the cost of new oil for the refill.
Old Jan 8, 2018 | 07:32 PM
The OP would be able to do this himself quite easily. Simply buy one of those suction pumps made for doing the oil change and have a clean container to suck the oil into. Once you have it all out you can measure it and then put it right back into the engine. Total cost would be less than $100 and take perhaps 20 minutes total.
Old Jan 8, 2018 | 07:37 PM
Old Jan 8, 2018 | 08:47 PM
OzXFR's Avatar
Agreed, and probably worth the cost for the peace of mind of knowing exactly how much oil was in there.
