Torque Specs on the lug nuts
Old Mar 30, 2019 | 10:00 AM
rbsj's Avatar
Default Torque Specs on the lug nuts
I have a '16 S V6 with original rotors. Anybody know the lug nut torque specs?
Old Mar 30, 2019 | 10:47 AM
sov211's Avatar
It is listed in your owner's manual...but I think it is 92 ft/lbs.
Old Mar 30, 2019 | 11:04 AM
DJS's Avatar
DJS
Gregory is correct.
Old Mar 30, 2019 | 05:47 PM
rbsj's Avatar
Thank you
Old Mar 30, 2019 | 06:10 PM
OzXFR's Avatar
Or else you can used my preferred spec of two grunts and a fart!
Also the tyre shop grease monkey with his pneumatic gun - "hey Joe, on this here Jagwaaar, is that three ugga-duggas or four?"
Old Mar 30, 2019 | 07:53 PM
DJS's Avatar
DJS
I could also just check to see what my torque wrench is set to - have never used it for anything else!
Old Mar 30, 2019 | 08:12 PM
OzXFR's Avatar
Same here!
Here in the civilised world we use Newton metres (Nm) to measure torque, and for the Jag lug nuts the correct spec is 125 Nm.
I have a nice big boofy 1/2" electronic torque wrench but two years after I bought it (I only bought it coz it was a nifty looking bit of kit and it was going at less than half price) I had still never used it so one day I decided to dig it out, fire it up and check the torque on the 5 lugs on one wheel that I had torqued up the day before using my trusty 1/2" breaker bar, 19 mm plastic sleeved socket and my tried and true two grunts and a fart method.
Lo and behold 4 of the 5 nuts registered smack on 125 Nm and the 5th one registered 123 Nm and tightened another 1/4 turn to 125 Nm.
Over the years I have worked out why my trusty method works so well on the Jag lug nuts - it's coz they are mag seat design as opposed to the more common acorn design, and just as they get to the correct torque they let out a little creak or squeak which acorn nuts don't do.
Old Mar 30, 2019 | 10:47 PM
Tork Monster's Avatar
92 lbs-ft is correct. And definitely use a torque wrench!
I broke off a stud on my F-Type hand-torquing using a 12" bar... shocked me. I did grease the studs (which I don't do anymore), and I didn't use a torque wrench (which I DO always now), but damn.
... and if you do break a stud Jag won't sell you a replacement stud.. they will sell you the whole damn hub, which is ~$550 US (plus installation)
I was lucky and my shop took it apart and was able to replace the broken stud without Jaguar's help... $18 + install
Old Mar 31, 2019 | 11:29 AM
Unhingd's Avatar
Originally Posted by Tork Monster
I did grease the studs (which I don't do anymore),....
I never used a lubricant, but have always used anti-sieze. It is still metal to metal (zinc) and prevents the fasteners from corroding together. Particularly useful on hub faces and hub-centrics to keep the wheel from freezing to the hub.
Old Apr 3, 2019 | 03:23 AM
planet_FType's Avatar
When tightening the lug nuts, don't be tempted to tighten each one right up to 92 lbs-ft. Tighten them all progressively, say 40 lbs-ft each, then again up to 92 lbs-ft.
Old Apr 3, 2019 | 04:36 PM
Unhingd's Avatar
better yet, get them all snug before you start the stepped torquing.
Old Apr 3, 2019 | 06:53 PM
OzXFR's Avatar
Yep, I've done it that way for 45 years.
First go "one grunt" (before dropping to the ground).
Second go "two grunts" (when on the ground).
Final go "two grunts and a fart".
Always in a star pattern.
Old Apr 4, 2019 | 06:34 AM
scm's Avatar
scm
I thought it was "tighten it until it snaps, then back it off half a turn".
Old Apr 4, 2019 | 01:43 PM
Carbuff2's Avatar
Darn! I only back off ONE FLAT when that happens! I've been doing it wrong. (But I HAVE been practicing to use the fart method. HehHeh.)
On a serious note:
I thought this was bad practice. I have released (or backed-off) my torque wrenches for years, supposedly to maintain their accuracy?
When a torque wrench is in regular use it does not need to be wound back. However, when storing a torque wrench for an extended period of time, users should always wind it down to the minimum scale setting and never to zero.
A fully loaded torque wrench, left in storage for a long period, can cause a ‘set’ in the spring, causing it to weaken over time. On the other end of the scale, by completely off-loading the spring, other components within the wrench may move fractionally relative to each other. When you reapply spring compression the orientation of these components can change, therefore affecting accuracy. All in all, it is better to leave a bit of compression in the spring while in storage.
https://www.norbar.com/en-gb/News-Ev...-torque-wrench
Old Apr 4, 2019 | 02:40 PM
DJS's Avatar
DJS
That's an excellent point. I hadn't heard that before, but it makes perfect sense. This is the only reason I bought my torque wrench.
MikeofBonsall
Jun 29, 2017 12:19 PM
REDTYPE
Sep 28, 2015 12:08 AM
Ozzlefinch
Feb 28, 2015 09:07 AM
hawaiianjag
Sep 13, 2010 01:42 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
