Trans Fluid
Old Jun 5, 2025 | 05:53 PM
spade's Avatar
Default Trans Fluid
How do I know when I should change my transmission fluid? Ive had the car for a year now but I only drive it like 2-3 times a month.
Old Jun 5, 2025 | 07:15 PM
rbr's Avatar
rbr
Though the trans was presented as "sealed for life", the consensus is that it should be changed at 60-80k miles. Not sure about a time requirement. Changing it requires replacing the pan, and filling is a bit fiddly.
Old Jun 5, 2025 | 07:16 PM
OzXFR's Avatar
The recommendation from ZF is every 70,000 miles.
Old Jun 5, 2025 | 08:55 PM
DJS's Avatar
DJS
I plan to have mine done this month, at 95k miles. My dealer resisted when I asked a year or two ago, but a local Indy knows how to change the ZF fluid. TheRock here has a good write up if you want to change it yourself. Requires an OBD scanner that can display transmission fluid temp.
Here’s the procedure, if you’re interested…
https://www.dropbox.com/scl/fi/cfr7s...=8qzmtgbv&dl=0
Old Jun 6, 2025 | 07:23 AM
Carbuff2's Avatar
Heres the procedure, if youre interested
We had success measuring transmission temp by simply measuring the case temperature with an touchless infrared laser pyrometer.
The worst thing about the process was burning myself on the HOT exhaust, which is really close to the fill hole! (I have a 4-post lift in my garage, too)
Old Jun 6, 2025 | 09:02 AM
Zen Beer's Avatar
Get Torque with the PIDS and a Bluetooth dongle to measure trans temps - Custom PIDs for Torque App - oil temp, oil level, trans temp, and more | Jaguar Forum
Old Jun 6, 2025 | 06:19 PM
Craaaazzy's Avatar
totally agree with this as same thing happened to me. Everything was easy up to having to put on the fill plug.
Old Jun 7, 2025 | 03:39 PM
jcb-memphis's Avatar
BMW indy shop will know how to do a zf8hp.
Blauparts have fluid/filter kits, what I used. I have no relationship with them. Used Ravenol fluid...no issues.
Old Jun 8, 2025 | 05:29 PM
SS4PK's Avatar
My Indy shop that specializes in jaguar, tells me we are waiting awhile every time I ask him. Mine has 60K on it now.
1992weezer
Sep 8, 2017 02:05 PM
jeffputts
26
Feb 4, 2012 11:10 AM
jaydid2
May 16, 2011 05:52 AM
