Tuning video for F Type R sports car
Old Aug 11, 2021 | 07:25 PM
Turko's Avatar
Default Tuning video for F Type R sports car
Hello Guys,
take a look at this video. How are they tuning this engine. What is it that they removed from the engine bay, is it the entire ECU ? Is this the preferred method to do an engine tune?
Old Aug 11, 2021 | 07:46 PM
Therock88's Avatar
Originally Posted by Turko
Hello Guys,
https://youtu.be/3njh1ZTkoyc
They removed the ECU and bench tuned it and then put it on a Dyno. Second question will cause all sorts of debate. Technically if you have a very knowledgeable tuner n your platform (rare), and they can tune and adjust while datalogging and testing on a dyno, they can dial it in optimally. Conversely, flash tunes that are more standardized are flashed through a flash device or PC through the OBDII port. These are usually (note usually) safe and there are more tests/examples of them in the market....So if they are safe, and no cars are blowing up, you are probably safe to use them also.
With the live tuning on the Dyno...If they do not know what they are doing, the results can be catastrophic.
DC
Old Aug 12, 2021 | 05:29 PM
ferrral's Avatar
780 ft/lbs of torque is gonna pop that ZF8, as mighty as it is.
Old Aug 12, 2021 | 07:08 PM
Craaaazzy's Avatar
780 nm != 780 ft lbs.
it’s about 575 ft lbs when converted.
Turko
Apr 25, 2021 10:41 AM
malbec
Mar 15, 2021 07:58 AM
Ubad2
Sep 24, 2016 07:56 AM
JimC64
Dec 26, 2014 08:54 AM
WaterDragon
May 23, 2013 12:05 PM
