V6S Tune
Old Jan 13, 2016 | 05:54 PM
  #121
Foosh's Avatar
Originally Posted by Unhingd
Out of consideration for the cost of dyno time and the fact we were seeing diminishing returns on the tuning tweaks, I decided to stick with the tune from Monday night. On that tune we also confirmed the accurate A/F ratios by inserting a threaded probe into one of the threaded bungs on the tailpipe. They all stayed nicely within the 11-12 range.
I am certain, with adequate dyno time that VMax could have wrung additional performance out of the engine, but with the clutch issue, there is limited value at this time. After completing a few other projects (clutch, short-shifter, etc.), I may take another crack at tuning with L.T. headers and an overdrive pulley.
VMAX,
Make sure you save that Monday night file for the V6.
Old Jan 13, 2016 | 10:16 PM
  #122
VMaxTuning's Avatar
Former Sponsor
Originally Posted by Foosh
VMAX,
Done and done.
Old Jan 21, 2016 | 01:08 PM
  #123
VMaxTuning's Avatar
Former Sponsor
The sale on V6 and V6S tuning continues at $1000 for ECU remapping (via OBD slave or send in benchflashing) and $150 for the 60.5mm upper SC pulley + shipping.
Thank You
VMax
Old Jan 23, 2016 | 12:09 PM
  #124
VMaxTuning's Avatar
Former Sponsor
A quick update: We'll soon (in the next 2-3 weeks) have results from a bench flashed 2017 AWD V6S stock vs ECU tune only. We'll also be able to confirm if our theory of non-detectability via SDD tool is correct when we bench flash the ECU vs OBD remap it.
Thank you
Old Jan 23, 2016 | 02:22 PM
  #125
Unhingd's Avatar
I don't quite understand the theory behind non-detectability. Unless you are able to hide the tune in a totally separate memory sector that is encrypted, the factory could simply run a "file compare" between their tune and what they pull off a tuned ECU. How do you plan to hide the tune?
Old Jan 23, 2016 | 02:44 PM
  #126
VMaxTuning's Avatar
Former Sponsor
Email sent Sir!
Bill
Old Jan 25, 2016 | 10:40 AM
  #127
Uncle Fishbits's Avatar
This thread is outstanding. Thanks to all involved. Cheers. I still cannot begin to comprehend all of this, but thank you so much.
I still think of "tuning" an engine as "two guys in overalls drinking moonshine and holding wrenches". Probably been a few years since that.....
Old Jan 25, 2016 | 10:45 AM
  #128
VMaxTuning's Avatar
Former Sponsor
We still drink moonshine, the wrenches we mainly throw at each other.
You are correct the days of tuning via a screwdriver (the kind without orange juice) are over but that doesn't mean we don't miss them.
Seeing that bowl of fire over the carb after nailing a WOT "tune" is a sorely missed memory for some of us here.
Thank You
VMax
Old Jan 25, 2016 | 01:14 PM
  #129
Speaking of missing them, you best be good at dodging the wrench...
Old Jan 25, 2016 | 01:18 PM
  #130
VMaxTuning's Avatar
Former Sponsor
If you can dodge a wrench, you can dodge a ball!! - YouTube
Love that movie.
"Dodge, dip, dive, duck, and dodge!"
Old Jan 25, 2016 | 01:44 PM
  #131
RickyJay52's Avatar
Default For The Record...
I sent VMAX/Bill an e-mail last night essentially asking, "what's this whole tune about?" and almost immediately received a comprehensive (as in detailed) answer. It's probably not for me but I certainly did appreciate the timeliness and attentiveness shown to me. Very professional...
Old Feb 6, 2016 | 08:45 PM
  #132
Unhingd's Avatar
It just occurred to me that my tuned V6 now has virtually the same hp, torque and weight as the M4. It would be nice to find out if the 0-60 is similar.
Old Feb 14, 2016 | 12:29 AM
  #133
Cambo's Avatar
I didn't realise before that only the V8's have a x-pipe with straight pipes from the factory, and the V6's have a resonator instead of the crossover.
So I guess you might pick up a few more horses by working on the exhaust center section. Actually I wonder if the V8 center section will bolt straight in...
Old Feb 14, 2016 | 05:32 AM
  #134
Unhingd's Avatar
Attachment 125481
Attachment 125482
It certainly would be louder and might add x amount of hp, but I would be concerned that it might destroy the symphonic sound coming from the V6. Because of the massive force of the lower frequencies coming from the V8, the unruliness of the resonator-less sound is appealing. From the higher frequency V6 sound, that type of unruliness might just result in annoying and cacophonous sound. If anyone tries this, please report back. I suppose we should hear shortly regarding the results of installing the 100/200 cell-cat and crossover pipe from VelocityAP.
Old Feb 14, 2016 | 02:52 PM
  #135
doctordeuce's Avatar
I had my resonator deleted back in April of 2014 and the car did not change at all in terms of the type of sound all that much, besides maybe becoming a bit more raspy. It was a bit louder as well. Last spring I added the Quicksilver exhaust and x-pipe...the car became much louder and the crackles became much more pronounced.
I am bring the car in to have the 200 cell sport cats installed on Tues (despite recent crap weather in Chicago). I am still deciding if I should have my car tuned locally while it can be on a dyno, or go with aforementioned tuners on this forum.
Old Feb 14, 2016 | 02:55 PM
  #136
Once the cats and tune are through, I would be really curious to see how the sound of my car would stack up against other F-type variants.
Old Feb 14, 2016 | 05:01 PM
  #137
Unhingd's Avatar
Unless your local tuner has extensive experience with the XKR or XJR, they will have no idea which files to enter to tweak the appropriate torque management nannies. My local tuner is widely renowned for his BMW (and MINI) and Porsche tuning, but was relatively ineffective with my V6S. From across the country, VMax was able to dial in with the data generated on the local dyno with the cooperation of my local performance shop.
Old Feb 15, 2016 | 07:32 AM
  #138
Tuning@VelocityAP's Avatar
I've been looking at Ftype 3.0 and 5.0 indepth..along both platforms of awd for 5.0 and obviously now both platforms for 3.0..I've done reads on them all. I've just finished comparing the base 3.0 to the S, if you look carefully you can ses the increases the factory made to get the boost in power for the S model.
Now I'm looking into the 5.0, same thing..even for the Project 7 which I now have a read to compare with...factory did the same increases to get Project 7 increase as they did for the 3.0 S version. There is still power on the table as vmax has found.
I know few pages back a lot have been debuting the difference if 3.0 to 5.0 S/C'rs..there 100% different..not even interchangeable..even the front snout is different in length. The 3.0L is shorter also in over all length. The 3.0L supercharger doesn't travel to the back of the block like the 5.0L version does.
On the older denso powertrain 5.0L, the charge bypass was vacuum controlled by a solenoid, the newer chargers(started with 3.0L, have a electric motor to control the bypass, the same bypass migrated to 5.0 when Bosch was adopted.
I have access to a test car, just not for tuning..so I'm presently researching to see if I can command more charge pressure and if the bypass will react as commanded.
I've seen the older units from the 4.2L, completely different style charger and bypass, that bypass worked with throttle control and was not in the charge valley, built into the charger like the 5.0 and 3.0 now have.
__________________
________________
Christopher Edgett
Technical Director
Velocity Automotive Performance Limited
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
Office Tel: (250) 485-5126
www.VelocityAP.com
Tuning@VelocityAP.com
Old Feb 15, 2016 | 08:32 AM
  #139
strippersteel's Avatar
Unhingd and doctordeuce thanks for the info on the V6 resonator. I didn't know it even had one. I might have mine cut out and replace with an x-pipe. If I do i'll report back the results
Old Feb 16, 2016 | 10:51 AM
  #140
Identical question, here. I have a feeling it's as simple as a dealer caring or not caring. If they care, they will compare. If they don't, they won't. Most will likely not compare until something goes wrong and they are trying to get out of the repair/covered stuff.
Anyway, you sent me a great PM about concerns of warranty.... Thanks.
Any sort of concern about voiding warranty aside, base '16 MT here... is it better to wait and have it all sorted with a final "this is what we can get out of the engine" tune?
IE I assume it will be more cost effective for you to work with Unhingd until you get it exactly where you want it, *THEN* roll it out to all the other cars?
I am sort of wondering if my neighbor who is my JLR dealer would be interested in this. He also has a McLaren and some other super cars, etc. I assume this is naive. =p
Also... is there a tutorial to help me figure out what I am looking out with this Tune. Youtube vid, etc?
OR... can you put in layman terms where the car ends up, IE 340hp on base 6cyl RWD MT ends up a 9 cyl 780hp spaceship.
Yes. I know the cars engine does not spontaneously reconfigure. Laws of thermodynamics apply. I've just had too much coffee.
