V8S vs V8R Vert
Old Oct 10, 2016 | 09:20 AM
Prophizee's Avatar
Default V8S vs V8R Vert
So i had quick question, been searching the forum with little success. What is the primary difference between the two V8S V8R vert. Besides the Hp and tq bump on the V8R. Is there any mechanical difference between the two.
Old Oct 10, 2016 | 11:00 AM
SamN44's Avatar
V8S: 2wd only, hydraulic assisted steering, 495hp (same engine hardware as V8R, software tune), minor visual differences with the hood vents (higher and centered on V8S. Also black on mine).
V8R: 4wd only, electric assisted steering, 550hp (software tune), lower and wider body colored hood vents, more aggressively styled lower door fenders.
Old Oct 10, 2016 | 11:07 AM
Prophizee's Avatar
It is wider even though I have the ground effects kit and lowered by how much
Old Oct 10, 2016 | 03:18 PM
SamN44's Avatar
The car itself is not lower or wider. I'm talking about the hood vents. Take a look at these two photos. Notice the more aggressive side skirts on the V8R and the different hood vent location and color.
V8S:
V8R:
Old Oct 10, 2016 | 03:49 PM
Prophizee's Avatar
I understand can we retro fit the bus with the v8r skirts
Old Oct 10, 2016 | 03:59 PM
Prophizee's Avatar
So then we what is the difference between the 2015 v8r and v8s, because in pics the 15 v8r skirts look identical to v8s
Old Oct 11, 2016 | 10:16 AM
DPelletier's Avatar
Depends whether or not you are comparing a V8S to a V8R RWD or a V8R AWD.....if both are RWD then the difference is limited to the engine software and any other year to year changes...if you are talking about the AWD, then there is that system and the related changes (engine slightly higher in the chassis, different hood/vents and wider sill trim)
Dave
Old Oct 11, 2016 | 01:20 PM
Tel's Avatar
Tel
V8R AWD and RWD has Torque Vectoring by Braking.
Old Oct 11, 2016 | 02:07 PM
Prophizee's Avatar
I actually knew about the torque vectoring...on side note just ordered my quicksilver exhaust so that should make for some fun. Is it a pretty straight forward install
Old Oct 11, 2016 | 04:25 PM
ShaunPA's Avatar
somebody should put together a sticky post for the model differentiation between the years. i swear the same questions come up again every few days
Old Oct 11, 2016 | 07:31 PM
2010 Kyanite XFR's Avatar
Sounds like we have a volunteer
DJP
Oct 14, 2016 05:15 PM
jbajor
Oct 10, 2016 07:55 AM
BurgXK8
Oct 7, 2016 12:02 PM
Prophizee
Oct 6, 2016 02:00 PM
