VAP ECU Flash Triggers P0420
Old Sep 30, 2020 | 04:38 AM
MisplacedPriorities's Avatar
Default VAP ECU Flash Triggers P0420
I've been trying to diagnose this persistent P0420 code for a while now. From my thread here: https://www.jaguarforums.com/forum/f...-p0420-235647/ I'm pretty sure the cats were bad.
But something else I've noticed that's peculiar...it may be related, maybe not. I was on the VAP Stage 1 tune via ECU flash. Thinking I'll have to take it to the dealer, I flashed it back to original. Strangely, after every flash, the P0420 code triggers. It doesn't matter what map I flash, it seems like the very act of flashing triggers the P0420. Anyone else have this happen, when trying to flash the ECU triggers a CEL?
Old Sep 30, 2020 | 05:36 AM
OzXFR's Avatar
I'm sure that flashing the tune on triggers the CEL and several error codes, this has happened to me all four or five times I have flashed and many others have also reported this. After a few drive cycles they disappear and don't return but I clear them all straight away using my iCarsoft LR 2.0.
The same thing will be happening to you with the exception of the P0420 code which for you is a "real" code.
Old Sep 30, 2020 | 06:18 AM
Good to know, thanks. When I asked VAP they said they had no idea, as in they never heard of it before...I just find it peculiar and maybe a little more than coincidental that it always triggers the same code that's making me lose sleep over.
Old Sep 30, 2020 | 08:37 AM
Therock88's Avatar
Agree with OZ, in that when you write to the ECU while the car is not running normally (i.e. when you flash/ upload the tune file) it will almost always generate a CEL, that should clear after a few cycles/starts. It will usually be related to communications/gateway/canbus, but can vary.
As long as the CEL is not on persistently (i.e. when you are not flashing or just flashed), it is likely not a "real" issue.
If you get that code under normal circumstances while just driving, then you likely have an issue. And of course, true Cat failure will typically result in a flashing CEL, and you should stop the car as soon as it is s safe to do so in that situation.
DC
Old Sep 30, 2020 | 11:23 AM
RGPV6S's Avatar
Every time I flashed a VAP tune the CEL light comes on. Never checked the codes being thrown. However after exactly five restarts it always goes away.
Old Oct 1, 2020 | 09:16 AM
madmax1911's Avatar
DC
Just learned something new again 👍
Old Oct 1, 2020 | 11:14 AM
lizzardo's Avatar
Interesting. I've never had a CEL from a reflash.
Old Oct 2, 2020 | 02:16 PM
Unhingd's Avatar
Same here.
Old Oct 2, 2020 | 04:02 PM
stmcknig's Avatar
I have usually had a CEL after flashing but I clear it with my fault code reader as I'm too impatient to wait five drive cycles...
Old Oct 28, 2020 | 04:41 PM
Tuning@VelocityAP's Avatar
It's not actually 5 drive cycles, it's just 5 engine starts back-to-back..
__________________
________________
Christopher Edgett
Technical Director
Velocity Automotive Performance Limited
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
Office Tel: (250) 485-5126
www.VelocityAP.com
Tuning@VelocityAP.com
Old Oct 29, 2020 | 03:45 PM
stmcknig's Avatar
You’re probably right Stuart, I told you I was too impatient to verify 😂
wmlaven
Sep 23, 2019 07:54 AM
MaximA
Jun 19, 2014 03:00 PM
jaguarlars
Apr 13, 2014 05:18 AM
Robinb
87
Feb 17, 2014 10:17 AM
BaDAss03STR
Sep 10, 2008 10:51 AM
