Velocity AP power package ?
Old Sep 6, 2020 | 06:52 AM
SinF's Avatar
Lets call what it is - you don't like VAP tune criticized, so you are looking for any way to throw my words into doubt by taking something I said out of context and discussing unrelated issues. Because racing fuel and carburetors are so relevant to tuning F-types.
VAP tune without intercooler and pump upgrades will make you heat soak unless you only race in cold weather. For most people who tune and never set a foot on a race track this is not a big deal. For street driving you can simply remove engine cover and call it done. I only heard of one heat-related engine failure in street use due to a tune (it wasn't VAP tune) and it was the result of a tuner overriding safety map. Obviously, VAP knows better than to make such rookie mistake.
Want to see that in action? Go to any dyno shop, don't let you car cool down after driving and do 5 pulls in a row. Last few pulls you won't have any tune. You will be able to see it yourself with back to back comparisons.
Old Sep 6, 2020 | 09:15 AM
Stohlen's Avatar
I won't argue this one bit; the stock tune will heat soak if you hot lap it. We know this.
Old Sep 6, 2020 | 09:21 AM
2004XJ8's Avatar
Anyone consider these are performance cars but not actual race cars? There is a big difference, in both design of components and systems such as cooling.
If you track them and damage happens it's the risk you take. As is any performance mods.
Old Sep 6, 2020 | 01:37 PM
supersportmtl's Avatar
If I were the OP I’d be discouraged by now... way to go gents on over complicating something that had been done hundreds of times without any issues.
Old Sep 6, 2020 | 02:13 PM
Hell Cat's Avatar
+1
OP I'd consider just reaching out to Stuart and the boys at VAP directly; they sound like they've got this platform pretty dialed in and can give you some professional recommendations.
I'll be all over downpipes and a tune as soon as they've got a sale going on
Old Sep 6, 2020 | 03:31 PM
SinF's Avatar
Stock tune without engine cover does fine with heat soak up until 100F degrees ambient or so. In most places with winter this doesn't happen that often. Meaning you can race most days and not have to worry about it. Not so much with a tune.
Old Sep 7, 2020 | 10:14 PM
Stuart@VelocityAP's Avatar
The only way to get more power is to get more air+fuel moving in through your engine. To get more air, you increase boost. VAP tune is no exception to that universal rule.
Boost is one way to increase power. However, it's only one piece of the puzzle. For example, the SVR makes more power than the R, but isn't making more boost. It's simply commanding more power through the torque driver demand tables. Basically, on any modern engine that's not in it's *ultimate* OEM configuration (ie, detuned) they are simply not opening the throttle all the way, to give an oversimplified explanation.
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
Old Sep 17, 2020 | 12:09 PM
  #28
Firesandftype923's Avatar
If you don't race, you can get away without intercooler upgrade. It takes me about 10 minutes driving flat-out (mostly WOT) to heat soak at ~110F degrees ambient with a stock setup, my best guess that with a tune it would be happening around 6-7 minutes range. It never happens at 90F and below.
I recall you mentioned that you race in Mexico, how hot is your typical track day? How long and how fast is you lap?
If all you do is stoplight "race", you don't need it. If you are serious about not spending lots of your precious track time doing cooldown laps or sitting in the pits with hood up, then you need to upgrade.
For me, I usually have 2 hour open track time, I like to split it to 45 min - rest - 45 min. On a very hot day my stock car can start pulling timing if I ride it all-out. This is V6S rear wheel drive, where I have larger oil pan than AWD and the same engine cooling system as V8, so I have more cooling relative to engine displacement than V8 would have. I know V6 stock runs slightly higher boost than V8 stock tune, but I also proportionally have more cooling.
Thank you so much for this reply , especially since it's starting to cool down here in Atlanta I'm going to hold off on the intercooler !
Old Sep 17, 2020 | 12:47 PM
Originally Posted by mws
both arguments about power increase are possible
1] increasing or at least, optimizing power with just a tune, and no pulley or waste gate control on a boosted car? absolutely possible. Not much, but possible.
2] most, but not all ECU tunes for this car include a pulley. Some don't
I have asked three times, now--have received no answer from the thread starter, and I think the most important question that NO one is compelling Firesandftype923 to answer is this: what the F happened to his motor? How, and why? This should be cause for alarm, I would think. Could effect all of us, at some point.
hey sorry I thought I replied on my other post it simply just locked on me while racing. Never really got a clear answer from dealership, but aslong as i got a new motor under warranty I wasn't gonna complain
Old Sep 17, 2020 | 01:00 PM
  #30
tec-9-7's Avatar
Originally Posted by Hell Cat
+1
This is by far the most insane thing I've ever heard! Reach out to the actual vendor?!?! Madness! Much better to just round-table speculate!
Old Sep 17, 2020 | 02:18 PM
  #31
mws's Avatar
mws
Originally Posted by J444G
As above mentioned, only tunes do nothing with boost. You really should learn a bit more before arguing with your tone about specific topic.
free motor with no questions asked: OK I can appreciate that. Sorry for being grouchy, but I just got done with a tech career in QA and also, took a few years off to repair cars for a living. I always "had" to know.
How about this: when and how did it happen?
late afternoon? super hot outside? First lap? was flogging it for hours? etc... any of that is helpful to draw a pattern for future forum users when and if the Indy shops start tearing down broken engines. Thanks!
Old Sep 22, 2020 | 04:51 AM
  #32
Your fine! Trust me I would wanna know aswell haha but I mean I'm not going to lie and say I don't drive really AGGRESIVE , I am 21 after all so I beat on her pretty hard and I did a few runs before it locked up and I did feel that my car wasn't 100% . Now that I'm looking back I believe they said they found metal shavings somewhere ( don't quote me on that )
Old Sep 22, 2020 | 07:35 AM
  #33
FLRRS's Avatar
Ha, this thread has me chuckling. Fireandftype923 was street racing i.e. a few hard WOT pulls, not doing laps on a road course. The term "racing in Mexico" is a euphuism for street racing that was made popular by a YouTube channel called 1320 videos. Yes tuning up the boost and running more power on a road course with sustained loads quickly heat soaks this motor in high ambient temps but a few 30 second pulls of WOT its mostly a none issue. Just different use cases.
F-Type R 16
Jan 7, 2022 03:17 PM
Firesandftype923
Sep 22, 2020 04:47 AM
dragonfire6
Sep 8, 2020 10:56 AM
RacerX
Sep 12, 2019 01:51 PM
sts-v
Jan 18, 2018 06:37 PM
