VelocityAP Jaguar F-Type ECU Tuning, V6, V6S, V8S, V8R
Old Apr 16, 2017 | 06:39 AM
  #441
RGPV6S's Avatar
Originally Posted by AJF
Hi KC_Jay I'm about to use my VAP, can you explain this to me? Do I need to disconnect the battery after I download the tune to my car ? Do I need to do this whenever I bring the tune back to stock?
I had no battery problems after installing my VAP tune. Just the check engine light that went out after 5 restarts.
Old Apr 16, 2017 | 06:41 AM
  #442
AJF's Avatar
AJF
Ah ok thanks.
Old Apr 16, 2017 | 07:19 AM
  #443
Unhingd's Avatar
I have found this to be the case on my car. It is not clear whether it has to be done on all cars. If your hazard light button remains lit for more than 10 minutes after the car is shut down, you will need to do the battery disconnect.
Old Apr 16, 2017 | 08:24 AM
  #444
AJF's Avatar
AJF
Got it thanks!
Old Apr 16, 2017 | 12:09 PM
  #445
KC_Jay's Avatar
Right. What unhinged said. You only have to do the battery disconnect if your car has the issue of not completely shutting down after you've used the ODB port.
Old Apr 16, 2017 | 12:13 PM
  #446
zmoothg's Avatar
Yes the same for me. I have to return to oem before I can guarantee a tune will take. It's quite weird to me as well.
Old Apr 17, 2017 | 07:58 AM
  #447
PunisherFType's Avatar
Originally Posted by Nati
curious to hear impressions from anyone with a V6S AWD who has done the tune without pulley. The published gains don't seem to be as great to my untrained eye - though I can understand why this might be. Just wondering if the feel is noticeable.
I have a 2016 F Type S AWD and have done the Tune and we deleted my CAT's as well as bumped the exhaust up to 2.5" piping with new mufflers.
I do not have dyno figures as I am waiting to do the pulley for these but the butt dyno can tell a difference.
Prior to this doing a hard launch was a piece of cake with TC still enabled, now it kicks in.
I have to kill traction control fully (not track mode) and when launching at 2500RPM it will still break the tires loose just a tad.
Old Apr 17, 2017 | 08:26 AM
  #448
Stohlen's Avatar
Odd... I flashed from one tune to the next yesterday and it was fine.
Old Apr 17, 2017 | 01:19 PM
  #449
Unhingd's Avatar
Unless there is a dramatic difference in the two non-OEM tune files, You might be unaware of the issue.
Old Apr 17, 2017 | 03:22 PM
  #450
Stohlen's Avatar
The Vtech tool confirms the right tune is in the vehicle, and we remapped the throttle pedal, which is quite noticeable. I'm confident the flash was successful.
Old Apr 17, 2017 | 05:56 PM
  #451
Unhingd's Avatar
Throttle mapping seems to be a critical consideration after massive power increases are implemented. Trying to dial down the front end sensitivity on mine as well.
Old Apr 20, 2017 | 11:00 PM
  #452
Cherry_560sel's Avatar
For those of you playing with multiple tunes, I have noticed that you have to flash back to the OEM tune before flashing the next one in order for it to take effect. This has now occurred on two separate occasions. It doesn't make much sense to me, but there you have it.
Chris did not mention that. How did you come about that bit of info?
VAP wrote a revised tune file in order to squeeze more low end torque, as the dyno results from the tune showed no torque gains from stock. I loaded the new tune, but have not noticed any difference. I am waiting for the OBD2 Link Sx to arrive so I can get some data using their OBDWiz software (I would welcome any comments regarding that scanner...it was super cheap, so I figured I would take a chance on it).
Old Apr 21, 2017 | 07:33 AM
  #453
Unhingd's Avatar
One of the times we were playing with tunes on the dyno, we had made a change to a tune that should have immediately registered some parameter changes, which it did not. Flashing back to OEM and then flashing the new tune provided the expected results. I then had the same issue occur while I was playing with alternate tunes to smooth out the throttle response. Nothing scientific about this. Just empirical evidence.
Go ahead and revert to OEM before putting on your new tune. It certainly won't hurt to try.
Old Apr 21, 2017 | 12:58 PM
  #454
Dan's cat's Avatar
Hello all! Newbie here. I am going to pick up my first Jag tomorrow, which is a 2014 F Type S. I a Z06, IS350 and a 380hp 335is and I really, really hope this one is more fun to drive than all of them.
I am going to do the tune after I pick up the car, but I will do the crank pulley a little later. Will I have to buy a second tune after putting on the crank pulley?? I hope not. lol
Old Apr 21, 2017 | 01:24 PM
  #455
Welcome...if you do the tune from VAP they have stated that the tune already is calibrated to accomodate the increased boost of the larger crank pulley.
Old Apr 21, 2017 | 01:31 PM
  #456
Stuart@VelocityAP's Avatar
Sponsor
Correct. And we don't charge for retunes either.
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
Old Apr 21, 2017 | 03:27 PM
  #457
Dan's cat's Avatar
That's great news! Thanks for the help Cherry_560sel & Stuart! And, I'll get in touch with you to start the process of the tune, Stuart. Thanks!
Old Apr 27, 2017 | 07:53 AM
  #458
inmanlanier's Avatar
After some off-line dialogue with Stuart (while he's in Asia!), I'm going to go with their tune. Since I will be doing some spirited driving at the local race track soon, I am trying to understand all the different driving modes (std automatic, "S", with paddles, tracdsc, etc). I have one question for all - how do we keep the car from downshifting??!! I want to know for a couple of reasons - the first of which is exiting from a turn at high g's - I don't want the resultant upset in the cars stability. The 2nd reason is that I want the dyno run to pull from down low if possible. The local AWD dyno here is limited to 150 mph, so we won't be in top gear. But in my limited experiments, it always wants to downshift. Any clues here as to how to force the car to stay in a given gear at lower RPM? thanks to all for this informative forum.
Old Apr 27, 2017 | 09:02 AM
  #459
DJS's Avatar
DJS
When in 'S', after you've used the paddles, it should only downshift:
1. If the RPMs drop low enough that it needs to downshift to avoid stalling;
2. If you put the pedal down to the 'kickdown' detent.
Old Apr 27, 2017 | 09:44 AM
  #460
Sponsor
As was noted, don't hit the kickdown switch and you should be fine. Also, I'll double check but I think 4th gear is the closest to 1:1, you don't want to be in top gear anyway.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
