VelocityAP Jaguar F-Type ECU Tuning, V6, V6S, V8S, V8R
Old Jul 7, 2016 | 07:43 AM
  #241
Stuart@VelocityAP's Avatar
Sponsor
Hi Everyone,
Finally managed to get the 'After' chart on our V8 Software upgrade demonstrating 42WHP gains (55BHP Crank.) Sorry the last one is a little cut off, not sure why they didn't have data recorded lower down but I know they had some issues with the car wanting to auto-downshift on the dyno so may be related to that.
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
Old Jul 8, 2016 | 11:24 AM
  #242
Dew1551's Avatar
I have a ECU that is from a special jag that could provide the programming used by Jaguar for the v8s..email me for details. dew1551@gmail.com
Old Jul 10, 2016 | 04:03 PM
  #243
Mpowerr's Avatar
Mods, you mind removing the above spam post? It contributes nothing to the conversation and is pretty disrespectful to Stuart and his team.
Just a thought.
Old Jul 10, 2016 | 04:09 PM
  #244
Sponsor
Don't worry it was actually intended for us, someone offering assistance actually
Old Jul 11, 2016 | 06:50 PM
  #245
Unhingd's Avatar
New V6S VAP tune (with upper and lower pulleys) data will be available on Friday. Short shifter badly needed.
Old Jul 11, 2016 | 07:59 PM
  #246
Smoke Em's Avatar
Looking forward to the results.. Good Luck!! Keep us posted.. Thank you
Old Jul 12, 2016 | 05:25 PM
  #247
Foosh's Avatar
Yep, looking forward to hearing about it, and will be will crossing my fingers for the health of the new clutch and flywheel. :-)
Old Jul 12, 2016 | 05:52 PM
  #248
Unhingd's Avatar
The clutch is holding up fine. It's the loose nut behind the wheel that is causing consternation. The dyno runs on Friday will tell the story far more accurately than I.
Old Jul 12, 2016 | 09:22 PM
  #249
RickyJay52's Avatar
Need I remind you oh Unhingd one? Engine in the front, drive to the rear, and a big smiling piece of meat in the middle.
Old Jul 15, 2016 | 01:43 PM
  #250
Unhingd's Avatar
Here are the preliminary results for the Velocity AP tune with 2.5% reduction upper and 11.8% oversize lower pulleys adjusted for 85% drivetrain efficiency:
OEM output: 365hp 313 lb-ft
VAP tune: 453hp 370 lb-ft
(Max)
My tuner has declared that the tune is safe and has not weakened any of the key nannies. I will post charts and tables tonight.
Ladies and gentlemen of the Tuned Brotherhood, shed your engine covers. They are capturing and not releasing massive amounts of manifold heat.
Last edited by Unhingd; Jul 15, 2016 at 05:26 PM. Reason: Keep forgetting that torque is not affected by drivetrain loss.
Old Jul 15, 2016 | 02:04 PM
  #251
BierNut's Avatar
edit - nevermind
Thanks for sharing!
Old Jul 15, 2016 | 02:08 PM
  #252
MI-FType's Avatar
OEM output: 365hp 368 lb-ft
VAP tune: 453hp 436 lb-ft
(Max)
Very impressive results!
Old Jul 15, 2016 | 02:21 PM
  #253
DJS's Avatar
DJS
I think you're about to find out just how good your new clutch is - that's a serious increase in torque!
With great power comes great responsibility...
Old Jul 15, 2016 | 02:23 PM
  #254
Sponsor
(Max)
Looking good Lance. Glad we could sort it out for you.
Let the floodgates open!
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Old Jul 15, 2016 | 02:34 PM
  #255
Unhingd's Avatar
Stuart,
Big thanks to you and Chris.
Old Jul 15, 2016 | 02:35 PM
  #256
Unhingd's Avatar
Dave, the new clutch is solid. Next stop: short shifter.
Old Jul 15, 2016 | 02:36 PM
  #257
schraderade's Avatar
(Max)
Congrats to you and Stuart: that is a stunning result!
Can you clarify what you mean by "declared safe"? Do you mean thermal range, rpms, etc?
Old Jul 15, 2016 | 02:48 PM
  #258
Unhingd's Avatar
Air/fuel ratios, timing, detonation limits, at all engine speeds. Only torque management has been minimized, leaving it up to the driver to keep it between the lines and out of the ditch.
Old Jul 15, 2016 | 04:34 PM
  #259
Mbourne's Avatar
Do you recommend the cover be removed even for non-tuned engines? The theory seems sound given your testing on the tuned side.
Old Jul 15, 2016 | 05:00 PM
  #260
Unhingd's Avatar
It's particularly true on pullied SCs that are pumping out 50% more boost, but there should be value on OEM tunes as well, particularly if you are pushing the engine hard.
