VelocityAP Symposer Delete Kit + Boost Reference
Old Feb 23, 2024 | 09:47 PM
samit's Avatar
Originally Posted by Therock88
That is a great add. I realize after looking at your post how much more room the V-6 has...Wow! I had no idea
It's definitely a bit tight with the V8. The bottom bolt is relatively simple to access with the symposer removed (as shown below), but even my smallest 1/4" ratchet with the shortest hex bit wouldn't fit between the upper bolt and the coolant crossover pipe. I guess it's time to invest in an extra short bit set...
Anyway, it's a very nice piece of hardware and definitely an improvement the modified OEM part + a silicone plug I had there before.
Old Feb 24, 2024 | 05:38 PM
lizzardo's Avatar
I just installed mine and decided it was time to go whole hog. I removed the symposer almost completely. There is a stub of hose I left on the firewall horn and I left the actuator in place. In another thread someone noted that removing it generates a harmless code (no CEL) and I didn't want to be bothered by that.
I was tempted to enable it and record the transition from off to on that I found so irritating, but I'm glad I didn't. It seems that the local rodentia did their own form of symposer defeat and chewed through the small plastic hose between the actuator and the symposer itself.
Installation of the VAP piece was about 15 minutes. The rest of the process added about three hours, but good riddance.
Old Feb 25, 2024 | 08:12 PM
samit's Avatar
Originally Posted by lizzardo
In another thread someone noted that removing it ]generates a harmless code (no CEL) and I didn't want to be bothered by that.
I think that was me. I never reinstalled the useless actuator and haven't seen any issues other than the harmless code since 2022.
Ouch, I hope they didn't find anything more important to chew on!
+1, I like the sound much better without the symposer and there's so much more room to access the rear of the engine. The next improvement for me is to replace the monstrous OEM plastic wiring harness support with something more elegant. Currently experimenting with this one:
Old Feb 26, 2024 | 06:29 AM
Andi Jaguar G's Avatar
How do you actually close the hole between the engine compartment and the driver's compartment?
Thank you so much for all answers... BR Andi
Old Feb 26, 2024 | 08:13 AM
f-driver's Avatar
closed the hole with a 25mm rubber cover from "PVC-Welt" www.pvc-welt.de
Grüße von und nach Bayern
Ulrich
Old Feb 26, 2024 | 09:13 AM
Therock88's Avatar
Grüße nach Bayern
Ulrich
Similar to the other post...I just made one from the original rubber hose and melted the cap with another piece of it and used the original clamp.. You cannot see this part when it is tucked away on the firewall.
Old Feb 26, 2024 | 09:30 AM
lizzardo's Avatar
I couldn't get the clamp off of the firewall end of that hose, so cut it off at a convenient spot (~3"), stuffed small roll of ensolite in it, and put on a cap I had in the workshop. I wanted to cap the piece directly but had wasted enough time on the clamp already and ran out of different pliers to try.
Old Feb 26, 2024 | 09:48 AM
  #28
DJS's Avatar
DJS
Sounds like something like this could work, if you can get a heat gun in there…
https://www.dxengineering.com/parts/nte-47-ec035
Old Feb 26, 2024 | 11:56 AM
samit's Avatar
I used a plastic plug I had lying around, with some neoprene rubber tape for a snug fit, but I think
a simple silicone plug a simple silicone plug
would work too.
Old Apr 28, 2024 | 01:27 PM
  #30
Jag Bass's Avatar
Those cars have no symposer to delete. I wonder what they have in place of the fitting, or if the port is even there. I don't have one handy to check.
Here is a 2020 with no symposer.
Old May 28, 2024 | 12:49 PM
  #31
GeorgeIII's Avatar
Symposer now completely removed (after just being blocked with the VAP blocker) . Additionally, metal heater pipes replaced the plastic ones....
Old May 28, 2024 | 02:04 PM
  #32
Ray Ray's Avatar
Where does the firewall side opening lead to inside the cabin?
Old May 28, 2024 | 04:04 PM
  #33
ftype_rick's Avatar
Can anyone speak to the change in sound from adding the delete? More natural, louder, etc.
Old Feb 26, 2025 | 02:43 PM
  #34
XSolerusX's Avatar
Originally Posted by Stuart@VelocityAP
Fun little product we just launched - either delete your symposer, add a boost reference take-off point, or both!
https://www.velocityap.com/product/s...j126-5-0aj133/
https://www.youtube.com/watch?v=8pkMfz_gu3E
any chance you have a returned one or could make a deal for a disabled veteran !?
Old Feb 27, 2025 | 10:37 AM
  #35
clubairth1's Avatar
Community Influencer
Ray Ray the blue plastic part as posted above is called the trumpet on the forum. But Jaguar calls it "The Feedback Device".
So far all of us have plugged the trumpet from the engine side and left it in place. If totally removed you then would need to fill the hole in the firewall anyway. So it's seems to make more sense to just leave that part be. Plus it's not in the way of anything so no downside.
Old Feb 28, 2025 | 11:27 AM
  #36
Evoex's Avatar
i would also like to hear from people who have done it, Type R owners would be a bonus!
Old Feb 28, 2025 | 11:36 AM
  #37
lizzardo's Avatar
Check out this thread:
https://www.jaguarforums.com/forum/f...defeat-171035/
Defeating the symposer is a two-minute operation and just as easily reversible. You can judge for yourself at no cost. Removal of the symposer is more difficult, especially on the V8, but you get the benefits of defeating it plus the extra room at the back of the engine for service operations. DC (Therock88) started a thread about removal. Note that this predates the availability of this kit from VAP:
https://www.jaguarforums.com/forum/f...emoval-240551/
Old Feb 28, 2025 | 11:39 AM
  #38
Evoex's Avatar
Thanks, I have some spring preventative maintenance coming up (SC removal, plugs, oil, belts, etc, etc, etc.) so it seems like a good time to yank it out.
Old Feb 28, 2025 | 11:44 AM
  #39
lizzardo's Avatar
If the SC is coming off that'd be the time to remove it. In the meantime, you can do the defeat and see what you think of the change in sound. I remember at least one person did not like the change, although most seem happy with it. I found the symposer particularly obnoxious, probably due to the manual transmission. It was really obvious when it switched on - modest acceleration, steady throttle, and then suddenly the disembodied drone appears.
Old Feb 28, 2025 | 02:15 PM
  #40
bjg625's Avatar
I've been following this for years but don't really understand the issue. What difference would it make to my '14 V6S?
