vp octain booster
Old Sep 16, 2022 | 06:50 PM
santacruz11's Avatar
Default vp octain booster
the can sez 21/2 oz per 10 gallons how the hell do u guys measure that at the gas pump ????
Old Sep 16, 2022 | 07:20 PM
lizzardo's Avatar
You can guesstimate how much fuel you'll be adding based on experience with the car and its gas gauge readings, then premeasure an appropriate amount into a container that you can pour from directly into the tank. Alternately, you can run the tank low enough that you know it will take more than ten gallons and add exactly that to go with the 2.5 ounces.
I'm not sure the container that VP comes in so don't know how easy it is to pour reasonably precise amounts.
EDIT: You could also get a syringe like that used for adding oil to the supercharger and put markings on the side calibrated in gallons of fuel. Fill up, suck the right amount into the syringe, then inject it. That has the disadvantage of adding after filling, so you don't get mixing action from incoming fuel.
Old Sep 16, 2022 | 07:42 PM
thanks have been using trick booster for years one can per tank , v p sez 32 oz per ten gallons. but on the back of the can it sez 2.6
Old Sep 16, 2022 | 07:48 PM
lizzardo's Avatar
The chart here indicates that 2.6 ounces should be right. Up to 32 ounces is possible for highly maintained racing engines.
https://vpracingfuels.com/product/oc...leaded/?c=207&
Old Sep 16, 2022 | 07:49 PM
thanks front of can sez treats up to ten gallons back sez use 2.6 per 10 gallons u tube sez one can per ten gallons vp ads say the same thing but prolonged use will cause engine damage if u use a 32 oz can for 10 gallons
Old Sep 16, 2022 | 08:01 PM
lizzardo's Avatar
"Up to 10 gallons" is the key phrase there. Be careful with information you get from youtube. It's a mixed bag. Taking youtube information at face value can lead to many kinds of problems, such as believing in a flat Earth.
Old Sep 16, 2022 | 10:26 PM
get real everyone knows the earth is flat !!! thanks for ur help
Old Sep 16, 2022 | 10:32 PM
thanks again now all i have to do figure out 2.6 oz have tt ask my wife for a measuring cup
Old Sep 17, 2022 | 12:03 AM
lizzardo's Avatar
Call me old-fashioned, but I'm going with Eratosthenes on this one.
rodan4170
Feb 7, 2020 05:45 PM
Dallas Rockford
Jan 22, 2020 10:27 AM
chazaroo
Nov 23, 2017 01:12 PM
fjcruiser
Jul 20, 2012 12:26 PM
Montru
20
Jul 24, 2011 04:49 PM
