Water Meth..
Old Jun 17, 2019 | 06:36 PM
  #41
Terrance39's Avatar
How is it a biased source? It's not like their saying that only their kits can be used on supercharged cars. They are saying that meth period is fine on supercharged cars I've seen this same info on multiple sites this is just one. People who have actually used meth with this style charger all say the same thing. It's fine to spray precharger etc. People like to repeat info from guys who heard from a friend of a friend. I take my info from the guys who actually run it. The forum is for enthusiasts looking for info. Would you rather me start a new thread on an already brought up topic? That's the whole reason of the search feature. Because I guarantee if I asked this question, I would be told to search because it was discussed before.
The whole you can't or shouldn't run it precharger debate.
Old Jun 17, 2019 | 09:32 PM
  #42
jackra_1's Avatar
I was only pointing out they are a sales company............of water/meth injection kits so I personally would not take their word on everything without some research.
Nothing more nothing less.
You will find my set up detailed in "quest for 450 hp".
I just found your post curious as an "out of the blue" post on a topic a year plus old.
Not that its bad as too many times people start a new thread when a thread already exists on a topic and it does make searching more difficult.
I was not intending to upset you.
Old Jun 23, 2019 | 07:30 PM
  #43
Mpowerr's Avatar
Please delete this post.
Old Mar 6, 2021 | 12:48 AM
  #44
bmcinsd's Avatar
Bringing it the thread back from the dead! Since my engine blew up (timing chain tensioner) last year my Aquamist Water Meth injection system has been sitting in my drawer. Now that the XFR is back to running, I wanted to see if anyone has installed a water meth system on their XFR lately? Curious as to where you put the nozzle(s) and where you got your signals from for the boost.
Old Mar 6, 2021 | 03:11 PM
  #45
Mbourne's Avatar
Recommend you post this in the XF thread as you have this in the Ftype thread. Good luck with your project.
Old Mar 7, 2021 | 12:07 PM
  #46
bmcinsd's Avatar
Thank you... Just realized I posted in F-Type forum.
Old Aug 23, 2021 | 05:22 AM
  #47
hammam almulhe's Avatar
Originally Posted by Philly Single
****...I put on a methanol system in late Spring 2016 and it runs like a damn champion.
at what psi do u set it to start injecting. Also, how much are u injecting?
Old Aug 23, 2021 | 05:27 AM
  #48
Originally Posted by FType17
That is not the supercharger, it's part of the intake manifold. You can see the two extra holes for the injectors with some black permanent marker
i’m running 4 (size 3 snowperformance) injection nozzles through the plenum in the next few days. Only reason i went with 4 instead of 2 is to ensure that all my cylenders are getting enough meth. Not planning to tune for it, so i have no clue how much i should inject and at what psi. Do you have an idea of how many cc/min i can inject without having the car running too rich?
im running the vap upper pulley + tune. So 11.5 psi is my max boost.
did not go with the crank pulley to not overwhelm my pistons with pressures and my differential with a high load of torque.
Old Aug 23, 2021 | 06:52 AM
  #49
Therock88's Avatar
Lots of variables to consider and not clear on what all you have on your car, so this is JUST A GUIDE.
Assume you are using a variable spray controller? If not, you should be. If variable spray, you SHOULD be safe to start spraying at ~30% throttle/boost, and spray can be full 100% around 70-80% throttle/boost (depending on what you are triggering from).
Do not even know what car you have as you have not indicated that...So again going to assume a V8 - 5.0 Liter (and you said 11.5 PSI boost), and ~ 7000RPM redline, the range of volume spraying should be on the low end 700ML/Min up to 1000 ML/Min.
Again, these are all guidelines. I am running dual nozzles @ ~800 ML/Min.
DC
Old Aug 23, 2021 | 07:23 AM
  #50
DC
hi. Hahhahaha yea sorry for not clarifying that. I have a 2015 f type R with an upper pulley, 200cell downpipes, itg maxogen COI, CWA100-3 sc pump, and aVAP tune. I also live in saudi arabia so it gets up to 120 degrees here regularly and 91AKI is our highest octane here. This is why i’m considering running more meth than water around 60/40 meth/water.
and yes my meth system is a variable spray stage 2E from snow performance + solenoid + a distributer. Each size 3 nozzle is 190ml/min so the 4 in total are 760ml/min at 100% duty cycle. My only concern is that i could be running too rich at 100% duty cycle on high boost levels. F
did you measure your AFR at 800 ml/min or maybe 100-200 draggy times at different duty cycles?
Old Aug 23, 2021 | 07:27 AM
  #51
Terrance39's Avatar
I am running dual nozzle on a dual pulley R. I start my spray at 4psi and ramp it up to full spray at 11psi. I'm seeing max boost at 14-15psi. Been running this for more than 2 years now, with zero issues. Car pulls hard and efficiently, with no heat soak. Also I started out spraying pre charger and saw little change in iat, so I stopped and just sprayed post charger. That gave me the best results.
Old Aug 23, 2021 | 07:31 AM
  #52
Terrance39's Avatar
Is that cwa100-3 pump plug and play?
Old Aug 23, 2021 | 07:33 AM
  #53
will find out in the next few days. I havent installed this and the meth kit yet
Old Aug 23, 2021 | 09:56 PM
  #54
Obi's Avatar
Obi
Will likely have to remove/reuse the cable from the stock pump
Old Aug 24, 2021 | 12:44 AM
  #55
removung and reusing the stock pump cables shouldnt take more than 10 minutes hopefully.
Old Aug 24, 2021 | 07:01 AM
  #56
Obi's Avatar
Obi
Accurate.
Side note, if you’re going with the wmi might as well get the lower pulley
Old Aug 24, 2021 | 07:04 AM
  #57
Accurate.
im sooo tempted to do that. Two things are stopping me. First is that i do not know how close im getting to the pistons’s tolerance with the 15psi that comes with the dual pulley. Second. I dont want to overwhelm my already sensitive differential with a **** load of torque.
Old Aug 24, 2021 | 07:50 AM
  #58
Obi's Avatar
Obi
This post didn’t age well 😂
Old Aug 24, 2021 | 07:52 AM
  #59
Obi's Avatar
Obi
Not for nothing, plenty forum members have went dual pulley without significant problem. But id hate for anything bad to happen to your car. Best of luck!
Old Aug 24, 2021 | 08:24 AM
  #60
Therock88's Avatar
You may glean some helpful info from my DIY on the install on mine...Lots of ways to do it, but this one is clean an unobtrusive.
Good luck.. LINK HERE
DC
