We (16MY AWD) a big problem
Old May 14, 2016 | 10:19 PM
  #81
Foosh's Avatar
Originally Posted by plums
Running a quart high has been a popular practice
amongst car hobbyists for decades. When the car
is thrown around, it helps to maintain a good
supply of oil around the oil pickup so it isn't
sucking air.
This is indeed true. The owner's manual of my C6 Z06 recommended exactly that before heading to the track.
Old May 14, 2016 | 10:24 PM
  #82
Unhingd's Avatar
Not even if you were talking static head pressure.
The oil pump is responsible for creating the pressure,
and will only flow what it flows. In fact, oil pressure
is a measure of the resistance to flow in the system.
So the time spent by the "someone" you called for
to educate me would be better spent giving you
some basic mechanical education.
plums,
you and I both must have graduated from a different mechanic school than the gentleman above. Oil pressure is produced by the oil pump and limited by the by-pass valve. Not even the deminimis additional head pressure at the sump caused by an extra 1cm of oil level will have any impact on the output pressure of the pump. The danger of a high oil level is moving parts whipping air into the oil causing oil pump cavitation, and subsequent loss of lubrication due to failing oil pressure.
Old May 14, 2016 | 10:29 PM
  #83
Foosh's Avatar
Originally Posted by Unhingd
plums,
The gentleman in question should follow his own advice and learn a little about how engines work.
Old May 14, 2016 | 10:53 PM
  #84
plums's Avatar
That is true and I almost posted a confirmation
of that in response to a post yesterday. But,
I figured it would be pretty much understood.
In any case, at least the 4.0L V8 has a windage
tray as well as the structural sump to dampen
the whipping.
If the oil is really high then you move
into the territory of bent/cracked rods, wiped
bearings and other such trauma.
But that is not the case for an extra quart.
Old May 14, 2016 | 11:08 PM
  #85
plums's Avatar
With that in mind, the slight overfill could be viewed as an
accidental favour performed by the various Jaguar techs that
have been flogged publicly here.
Old May 14, 2016 | 11:31 PM
  #86
plums's Avatar
Originally Posted by Chris starko
I check the oil daily almost and change the oil/filter myself every 3k miles ...
2016.05.14
Also, in my case, the dealer put in 8 quarts the instead of 6.5 ...
cough!
NJ2003XJ8
Apr 7, 2016 07:12 PM
vicmoschella
Apr 6, 2016 03:04 PM
Andi Allko
Apr 4, 2016 04:06 PM
oyster
Apr 3, 2016 09:41 AM
Zain
Mar 30, 2016 12:59 PM
