what is this engine noise ?
Old Dec 7, 2024 | 10:43 AM
juliam's Avatar
Default what is this engine noise ?
https://youtube.com/shorts/7oAymjZa0J0?si=n4NG-SiIGeJeZpAw
i replaced the coupler to a solid coupler. the noise is coming from the front of the engine, kinda sounds like the supercharger. still not sure. please help
Old Dec 8, 2024 | 04:27 AM
Clearbo666's Avatar
If the noise goes once the engine is warm, it's likely to be the fuel pump.
Old Dec 8, 2024 | 04:41 AM
OzXFR's Avatar
Doesn't sound like the SC coupler to me, too regular and even.
Yes it could be one or both of the high pressure fuel pumps (there are two of them).
They sit on the RHS of the block (looking from the driver's seat) down low towards the front, one behind the other.
Get the car up on a lift, remove the rubber covers, and listen with an automotive stethoscope.
That said it could be SC bearing(s).
Old Dec 8, 2024 | 06:46 AM
WSHudds's Avatar
Car model, age, mileage and recent history of parts replaced (if any) always lead to better advice.
Old Dec 8, 2024 | 07:22 AM
clubairth1's Avatar
Community Influencer
What solid coupler did you use? Many threads on this and the solid ones can cause problems.
Old Dec 8, 2024 | 09:10 AM
juliam's Avatar
2016 F type V6 66,000 miles oil changes every 3,000 miles and it just had full euro amp coolant system replaced with the oem eaton solid coupler.
Old Dec 8, 2024 | 09:11 AM
juliam's Avatar
So is that normal ?
Old Dec 8, 2024 | 09:12 AM
juliam's Avatar
Had the bearings inspected while the supercharger was out and they look good.
Old Dec 13, 2024 | 11:37 AM
kansanbrit's Avatar
Take the SC belt off and start it, that will you if it's in the SC. If not take the main belt off and try it. Sounds like Idler pulley maybe.......
Old Dec 13, 2024 | 01:34 PM
waldo's Avatar
A few months ago, I replaced the factory supercharger coupler in my '16 F-Type (V6) with a genuine Eaton replacement coupler. I immediately noticed an increase in noise from the front of the supercharger. I removed and replaced the Eaton coupler with a ZZP solid coupler, and the noise went away. I have videos, pictures, and additional details in this thread: 2016 F-Type R - Supercharger Isolator
Old Dec 17, 2024 | 09:27 AM
clubairth1's Avatar
Eaton makes a different coupler for the V-6 and the V-8. Which part number did you install?
Old Dec 18, 2024 | 03:17 PM
waldo's Avatar
Eaton makes a different coupler for the V-6 and the V-8. Which part number did you install?.
From my research on this forum, the AJ126 V6s and 2017+ AJ133 V8s both use a 49mm coupler (or 50mm, depending on how you measure it). The Eaton part number for the 49mm coupler is EAT-361506. That's what I installed and eventually replaced with a ZZP coupler.
The pre-2017 V8s would need EAT-85914. That’s a 47.5mm coupler designed for the Eaton M-90 and M-112 superchargers. ZZP also makes a 47.5mm coupler for the earlier V8 superchargers.
Marrakechhack
Jul 3, 2024 04:12 PM
Manuel1234
Jan 4, 2024 06:27 PM
vincent661983
Sep 29, 2014 05:46 AM
reyesl
Mar 19, 2014 09:13 AM
