What is this part? Need ID help.
Old Dec 18, 2024 | 05:30 PM
SurfCat's Avatar
Default What is this part? Need ID help.
Hello, I was looking at the front end of my 2015 S Convertible and noticed that these parts were broken. The bottom looks to connect to the lower spoiler or front deflector? I am hoping that this is not a part of the front clip / bumper cover. Neither the spoiler or deflector have a noticeable droop but i want to get these replaced. If anyone could give me some part numbers or some guidance on this it would be extremely appreciated.
Old Dec 18, 2024 | 07:22 PM
OzXFR's Avatar
See here: https://www.jaguarparts.com/v-2015-j...mponents-front
The deflector is part # 11 on the main diagram, I replaced mine several years ago, a fairly easy DIY. Part # T2R3562 for the gloss black version.
I *think* the broken plastic behind that (e.g. the two vertical pieces that have cracked in half) is an integral part of the front bumper cover, held on with plasti-rivets and glue.
If so you will need a new bumper cover, part # 1 on the main diagram, and not exactly cheap. And that is before painting which would cost a bunch more.
Maybe just maybe the broken bits can be plasti-welded back together which would be a helluva lot cheaper.
Old Dec 20, 2024 | 10:27 AM
SurfCat's Avatar
OzXFR, Thanks for the reply. I went in search of a replacement bumper cover and was able to find some already removed from their cars. It looks like the brackets that are broken on mine are not integral to the bumper cover but maybe to the deflector #11 in the diagram you referenced. However, the diagram does not indicate any brackets attached to the deflector. I am wondering if they are parts 14 & 15 in the diagram, reinforced bracket, C2P24129 & C2P24130. The picture that i was able to locate, a view from the inside of the bumper cover, is not clear enough to show how those are connected. The diagram shows no holes, so I am still somewhat in the dark on this.
Missing deflector and no brackets
Deflector installed with brackets
Brackets from the inside.
MajorTom
Mar 11, 2022 04:34 PM
lpf4
Aug 2, 2020 05:28 PM
BC XJS
Feb 19, 2016 09:45 PM
Bc xj
Nov 12, 2015 01:33 AM
clnilsen
Jun 6, 2011 08:12 AM
