Wheel torque
Old Dec 26, 2014 | 09:34 AM
zach05855's Avatar
Default Wheel torque
Sorry if this is already posted, nothing came up on the search.
Does anyone know the proper wheel torque?
even the Google came up with nothing.
Old Dec 26, 2014 | 09:46 AM
buickfunnycar.com's Avatar
In the tire changing section from the owners manual it states 92 lb ft....which sounded like a lot for what seems to be a 7/16" stud.
Old Dec 26, 2014 | 09:47 AM
zach05855's Avatar
thanks,
Old Dec 26, 2014 | 09:55 AM
Foosh's Avatar
Buick is correct.
Old Dec 26, 2014 | 09:58 AM
Just re-checked...it's on the upper left hand corner on page 203.
Old Dec 26, 2014 | 11:29 AM
Unhingd's Avatar
The torque required will generally be a function of stud diameter and thread pitch. For example, the Gen 1 (2002-6) MINIs call for an 85 ft-lb torque where the Gen 2 & 3 (2007-present) MINIs call for 103 ft-lb. Though the bolt diameter is the same (17mm), they changed the pitch from fine thread to coarse in 2007, which is the reason for the torque change. The MINI mechanics that I have spoken to claim to tighten the bolts at 90 ft-lb regardless of year.
Old Dec 27, 2014 | 04:35 AM
F-typical's Avatar
Hmm... Mk1 had M12 wheel bolts through to 2006, when the spec was changed to M14.
I upgraded my Mk1 S Works to the M14 bolts in 2008 when I fitted the Mk2 Works brakes (the Brembo 4-pots).
17mm is the size of the socket used to tighten the bolts.
Old Dec 27, 2014 | 05:58 AM
Unhingd's Avatar
Yes, bad brain day yesterday. I was remembering the wrong dimension. The only thing I got right was the pitch change which went from 1.50 to 1.25 when the diameter went from 12 to 14mm. Given the F-Type lug is 12mm, the 92 ft-lb seems reasonable.
aholbro1
Dec 29, 2024 06:46 PM
mrplow58
Jan 21, 2024 05:53 AM
Neil1664
Jan 20, 2022 08:59 PM
chatmanx
Sep 11, 2015 07:17 PM
iownme
Sep 11, 2015 02:57 AM
