Whirring in the engine compartment!
Old Nov 1, 2022 | 09:59 AM
Andi Jaguar G's Avatar
Default Whirring in the engine compartment!
please help, I've been hearing this buzzing noise in the background for quite some time, I think it's a very bright electronic buzzing from a unit. No mechanical problem. what could be there.
In the middle under the engine I think...
Thank you for all replies...
BR
Andi
File Type: zip
Old Nov 1, 2022 | 10:33 AM
scm's Avatar
scm
Fuel pump?
Old Nov 1, 2022 | 10:37 AM
Originally Posted by scm
Fuel pump?
Perhaps, it is possible... Thank you
Old Nov 1, 2022 | 12:20 PM
zach05855's Avatar
I have a Buzzing noise that sounds like it is coming from the center. I found the source and there are several threads on this sound. It is the A/C pressure line the crosses along the firewall near the wiper.
Old Nov 1, 2022 | 12:56 PM
Is your Sound the same as mine in the File?
Thank you
Andi
Old Nov 1, 2022 | 02:43 PM
zach05855's Avatar
Thank you
Andi
Could be, Mine cycles with the A/C compressor
here is the other thread
https://www.jaguarforums.com/forum/s...rchid=14662769
Old Nov 2, 2022 | 03:32 AM
Hi,
is the Fuel pump in the front of the car below the engine? I think the alternator could also be the culprit.
BR
Andi
Old Nov 2, 2022 | 03:51 AM
OzXFR's Avatar
Hi,
BR
Andi
The F-Type V6 and V8 have three fuel pumps, a low pressure pump in the fuel tank and two high pressure fuel pumps down low on the right hand side of the engine block, one behind the other.
The front one of those two HP fuel pumps is towards the front of the engine and those pumps have been known to become noisy so that could explain your noise.
Edit - attached is a page from the AJ133 (V8) Technical Training pdf showing the front (primary) high pressure fuel pump. The secondary pump is immediately behind it, just not shown in the diagram.
File Type: pdf
Old Nov 2, 2022 | 07:04 AM
thank you so much for this important feedback...
Andi
Old Nov 2, 2022 | 08:56 AM
In the spare parts shop in Germany I can only find one high-pressure pump, not a second one...or are the same pumps installed twice here?
THX
Andi
Old Nov 2, 2022 | 06:11 PM
OzXFR's Avatar
THX
Andi
I'm not sure but I seem to remember someone commenting around here somewhere that the two pumps are different with different part numbers.
Try searching for "primary high pressure fuel pump" and "secondary high pressure fuel pump".
Old Nov 3, 2022 | 02:06 AM
Thank you, I have the info...
It looks like, than both pumps are the same
DESCRIPTION SRO TIME (HOURS) CONDITION CODE CAUSAL PART
High pressure fuel pump - Front - F-TYPE (X152) 19.45.30 2.8 42 C2Z22287
High pressure fuel pump - Rear - F-TYPE (X152) 19.45.31 2.8 42 C2Z22287
BR
Andi
Old Nov 3, 2022 | 04:32 AM
Obi's Avatar
Obi
BR
Andi
1 pump for each side of the V
Old Nov 3, 2022 | 05:04 AM
ah ok, but both pump are on one side installed at the engine, i understood...
Old Nov 7, 2022 | 08:28 AM
schuss's Avatar
Yes, both driven by the same driveshaft. I think it's so interesting they are chain drive pumps rather than electric.
SanFran
Oct 1, 2022 01:04 PM
vincent661983
Sep 29, 2014 05:46 AM
reyesl
Mar 19, 2014 09:13 AM
santos007
Jun 14, 2013 10:32 AM
TonyW
Jul 27, 2009 05:33 PM
