Wow Jaguar....Stereo all fixed finally!!
Old Sep 6, 2018 | 04:10 PM
  #301
eeeeek's Avatar
Car is back. Verdict: meh. It is different. The volume control is vastly different (now 15 is about where 25 was before). Bass still sounds poor.
Old Sep 6, 2018 | 04:57 PM
  #302
speedski's Avatar
I guess it depends what your expectations were. Before the update, the bass frequency response on my stereo was absolute garbage because the bass was being sent to the wrong speakers. With bass it sounded worse than pretty much any car stereo out there to the point that I didn't listen to music on it. After the update, the bass frequency response was greatly improved but I would still describe it as muddy by audiophile standards. For me going from garbage to muddy was a huge difference. If you play around with the different audio modes and settings you can get it to sound OK though it's still far from being audiophile quality.
Old Sep 6, 2018 | 05:34 PM
  #303
usgpru27's Avatar
Speedski, Thanks for the update. My MY17 is going in for a variety of repairs soon and the audio is one of the issues. Based on your experience would you think that the speaker upgrades from the Rover and XJ would be the step to take it to an acceptable level? Does it have better separation do you feel? The speaker upgrade is about $700 without a solution for the ones behind the seats. Thanks for any insight.
Old Sep 6, 2018 | 05:40 PM
  #304
speedski's Avatar
Honestly, I have not heard of any speaker upgrades for the 2017 F-Type. In the states, I believe all 2017s came with 770W Meridian stereo, even my base F-Type. My recommendation would be to have fix applied and see if makes the stereo acceptable to you. If not, then I honestly am not sure what the next best step would be since I haven't heard of anyone putting aftermarket stereo or speakers in the F-Type.
I guess my recommendation at that point is to listen to the active exhaust instead of the stereo, which is what I do most of the time I am driving my F-Type.
Old Sep 6, 2018 | 08:41 PM
  #305
Chawumba's Avatar
Like you, I was underwhelmed at first. But after playing with settings and living with it a while, it definitely seems better. To the point where sometimes I turn it on after driving another car and think, hey, it sounds pretty good.
Old Sep 7, 2018 | 12:12 AM
  #306
Arne's Avatar
What settings do you use?
Old Sep 7, 2018 | 11:46 AM
  #307
eeeeek's Avatar
Could you let me know what settings you went with? After playing a bit, I just went back to flat (all settings at default).
Side note: It sounds way worse on satellite radio.
Old Sep 7, 2018 | 12:21 PM
  #308
Arne's Avatar
Do you use Dolby, DTS or Meridian in the setting?
I prefere Dolby or DTS (which sounds rather similar after the software upgrade). The Meridian setting lack bass and is very front speaker related.
Old Sep 7, 2018 | 01:12 PM
  #309
speedski's Avatar
I also experienced this however I would not use Satellite radio as a judge of music quality because they compress the hell out of it. I think they compress it between 32 kbps to 64 kbps which is much lower than the standard 160 kbps for Spotify. Probably the reason that it sounds “worse” is that after the fix you have better sound from other sources, including HD radio. The fact that you can now tell the difference is probably a sign of a higher quality system.
Old Sep 7, 2018 | 01:14 PM
  #310
DJS's Avatar
DJS
Many of us have agreed that the F-type (at least early MYs) has a worse satellite radio implementation than other cars.
Old Sep 7, 2018 | 02:25 PM
  #311
Unhingd's Avatar
+1. I found the Dolby setting sounds best after the service bulletin was applied.
Old Sep 7, 2018 | 05:47 PM
  #312
jaguny's Avatar
There are oem speaker upgrades that I have done and that are documented earlier in this thread that I believe is a significant improvement.
Old Sep 7, 2018 | 06:24 PM
  #313
OzXFR's Avatar
I have the 770W system and have never had any of these poor sound quality issues.
My car was originally a dealer demo so it may have had the fix applied, but there is no paperwork or electronic history showing this and I will never know.
I have it set to Meridian and I get great sound from all sources, including MP3s on a USB and DAB radio (is that the same as satellite radio?).
The only time the sound is less than great is if/when I play a low bitrate track on the USB, and that is obviously down to the relatively poor source in the first place.
Old Sep 8, 2018 | 05:24 PM
  #314
Vongolet's Avatar
Does this bulletin apply to the 2014 770W system?
Old Sep 8, 2018 | 08:10 PM
  #315
Unhingd's Avatar
I don't think it applies to the vert.
Old Sep 9, 2018 | 03:50 AM
  #316
Vongolet's Avatar
I'm actually talking about a coupe
Old Sep 9, 2018 | 04:17 AM
  #317
Arne's Avatar
Then I think it should apply.
Mine is a MY2015 made in 2014, and it did apply to mine. Made a nice improvement.
Old Sep 9, 2018 | 09:57 AM
  #318
Unhingd's Avatar
Didn't realize you were non-US. Thought you had an MY2014. No coupes built that production cycle (4/2013-3/2014).
Old Sep 20, 2018 | 11:44 AM
  #319
ssaeed1973's Avatar
Default How to tell if I need update?
Is there a version number for the stereo firmware I can lookup to see if the upgrade has already been applied? I have a MY’17 type R.
Old Sep 20, 2018 | 02:31 PM
  #320
Unhingd's Avatar
Vert or Coupe?
