1986 XJ6 no spark
Old Jun 21, 2019 | 11:26 PM
JagXK2007's Avatar
Default 1986 XJ6 no spark
Okay, just so everyone knows to check this first before checking everything else. If you lose spark, Please check the damn Coil Resistor. My son's burned out after parking and attempting to start a few hours later. After a quick look over and deciding the fuel pump had failed, I had the car towed home. Then after replacing the fuel pump and ignition coil, and ignition amplifier, I discovered the damned coil resistor was burned out. I removed it and she started and ran great. This car has the electronic ignition and consequently, does NOT need the resistor which primarily was to keep the points from wearing out sooner. So, if I had read this info from someone else and had some troubleshooting advice it would have been zero cost to fix.
Lagonia
Feb 12, 2022 11:18 PM
Scott Elliott
Jan 19, 2014 07:19 PM
GvilleVDP
Jun 6, 2013 08:20 AM
dsetter
Jun 20, 2012 10:55 AM
SteveJacks
Dec 7, 2011 06:50 AM
