1996 XJR throttle adjustment
Old Feb 11, 2013 | 11:15 AM
speedfreak2030's Avatar
Default 1996 XJR throttle adjustment
1996 Jaguar XJR throttle adjustment. If I use my scanner to see throttle % open at idle is at .8 or 800 RPM, wide open throttle 78%. If I adjust WOT to 100% using the adjustment in the cable assembly my idle goes to 18% reving the engine to 1800 rpm. I can't find the sweet spot .8 and 100%. What am I doing wrong? is there a better way to adjust WOT as the performance of the car is poor for a supercharged engine.
Old Feb 15, 2013 | 11:48 AM
xjrguy's Avatar
First you have to get the two throttle cables and the TRACS unit adjusted. I had posted the procedure many moons ago:
here: https://www.jaguarforums.com/forum/x...94/#post335715
Then you might likely have to modify the stud under the throttle pedal that holds the trans kickdown switch. I usually remove it, and fabricate a replacement with a bolt that I cut the head off of. Then use a couple of nuts as jamb nuts to work like the hex body of the stud you took out. [only shorter] That way you can extent the travel of the pedal for a full stroke on the throttle body cable.
Good luck!
Old Feb 25, 2013 | 10:46 PM
jeremiahjaguar's Avatar
have you resolved this problem?. new problem for me also, trying to figure it out. cable is adjusted and tracks are adjusted, same problem. I will take a look tomorrow again.
xjrjag
Oct 24, 2024 03:09 PM
Gus
Oct 15, 2019 12:29 PM
Vee
Sep 13, 2015 12:19 PM
SouthernGypsy
Sep 3, 2015 10:54 AM
