2000 Lincoln LS 3.9 (4.0 Jag)timing chain questions
Old Jan 12, 2014 | 02:59 PM
skynyrdmh's Avatar
Default 2000 Lincoln LS 3.9 (4.0 Jag)timing chain questions
Hey all, from what I understand the 3.9 in my LS is the same 4.0 Jag engine. I need to replace the main timing chain rails and have read the original ones are plastic and the new style are metal. Are the OE rails plastic wrapped around a metal core?? My rails are just this. I am wondering if the rails have already been updated once. Any and all help would be appreciated.
Old Jan 12, 2014 | 05:10 PM
Welcome to the forum skynrdmh,
You will find plenty of information on tensioners in the Engine section of XK8/XKR tech forum FAQ's:
https://www.jaguarforums.com/forum/x...ts-data-29800/
Old Jan 12, 2014 | 07:21 PM
motorcarman's Avatar
The LS engine is SIMILAR but NOT the same.
LS engines lack VVT.
The primary chain guides are plastic covered steel.
The secondary tensioners are aluminum body units with plastic 'slippers'.
bob gauff
xjrjag
Nov 27, 2025 09:16 AM
celticpiping
Sep 18, 2015 06:17 PM
Bcrary3
Sep 12, 2015 08:43 AM
h4wk
Sep 3, 2015 08:05 PM
souldoubt
Aug 25, 2015 08:15 PM
