2013 jaguar xf..2.0L
Old Sep 30, 2015 | 05:12 AM
Maaden's Avatar
Default 2013 jaguar xf..2.0L
Gents.
Plz help me. Engine oil change. Is there is drain plug??or has to be sucked out?
Old Sep 30, 2015 | 05:32 AM
Fraser Mitchell's Avatar
Is there no dealer in Saudi Arabia who can tell you ? FWIW my local independent suck the oil out via the dip stick hole but the engine does have a drain plug. I'm not too sure on the 2 litre, which is, I assume, petrol, but it will be a Ford engine, probably the same one fitted to the new XE 2 litre petrol.
Old Sep 30, 2015 | 05:34 AM
Maaden's Avatar
Is there no dealer in Saudi Arabia who can tell you ? FWIW my local independent suck the oil out via the dip stick hole but the engine does have a drain plug. I'm not too sure on the 2 litre, which is, I assume, petrol, but it will be a Ford engine.
First thank you for ur reply. There is dealer here but they are charging too much and i would like to change it by myself. My car petrol .
Old Sep 30, 2015 | 07:20 AM
Originally Posted by Maaden
....... Is there is drain plug??or has to be sucked out?
According to the Parts Catalogue, there is a sump drain plug on the XF 2.0 litre petrol engine. See item 5:
In future, please post technical questions about your model in the X250 forum:
XF and XFR ( X250 ) - Jaguar Forums - Jaguar Enthusiasts Forum
You will then receive replies from members with the same model.
Old Sep 30, 2015 | 09:15 AM
Maaden's Avatar
Attachment 119418
Many thanks ..i will do..
D.K
Dec 10, 2023 02:05 AM
paulyling
Mark V - X 420G
Aug 15, 2023 09:33 PM
SD96XJ6L
Jan 12, 2022 04:30 AM
David Thompson
Sep 3, 2015 07:48 PM
Harry Dredge
Sep 3, 2015 03:04 AM
