2014 Xf Coolant leak help.
I got a 2014 XF with a bad coolant leak. It’s leaks out as fast as I can poor in the water. Well almost as fast. I see water coming out under the water pump. So I took it off and water on the head too. I thought about the small coolant lines under the SC. But I jut don’t think they are big enough to flow that much water that fast. Does it even when not running
