5.0 SC Crankshaft main Journal size
Old Dec 18, 2020 | 09:57 AM
ken sampson's Avatar
Default 5.0 SC Crankshaft main Journal size
Would anyone know what the 5.0 AJ133 SC Crankshaft main Journal size is? If I had to guess i would say 2.652". maybe somene has one they can messure?
Old Dec 20, 2020 | 07:15 AM
Paul_59's Avatar
Banned
Sorry I can't answer your question.
You may find this manual useful if you haven't already got a copy.
AJ133 5.0L V8 JLR engine
Old Dec 20, 2020 | 01:53 PM
motorcarman's Avatar
If the engine is much like the 4.0 and 4.2 V8 then there will be a 'matrix' to select the correct bearing from a code on the block.
The choices are related to the block dimension and the crankshaft journal and then a color coded bearing is selected.
It is not a simple as a 'one-size-fits-all' bearing.
Old Feb 26, 2022 | 07:03 AM
Kensampson's Avatar
Default 5.0 engine
I just wish There was a way to confirm if all the 5.0 blocks are the same
Old Mar 4, 2022 | 07:19 PM
Kensampson's Avatar
I would be satisfied with the measurement from a tape measure just trying to find out if you're 3" or 2- 5/8 not looking for the exact size thank you
Showtime Jesse
Aug 2, 2020 11:46 AM
AlexJag
May 29, 2020 04:49 PM
greenforest56
Jan 5, 2018 04:08 AM
SD96XJ6L
Jun 29, 2015 12:58 PM
