98 xj8 with code 1336
Old Jan 20, 2014 | 03:18 PM
Roy's Avatar
Roy
Default 98 xj8 with code 1336
this is crank,cam position sensor error but are there only one of each or is there more than one cam sensor? if there is more than one where is it located at thanks for the help
Old Jan 20, 2014 | 05:47 PM
Roy,
I can see you've posted in three different model tech sections and have to assume you are having difficulty finding the right place to post questions about your 1998 XJ8.
Its X308 section:
XJ ( X308 ) XJ8 / XJR - Jaguar Forums - Jaguar Enthusiasts Forum
Once you reply to tell me you've seen this, I'll move this thread to X308 section for you.
Old Jan 20, 2014 | 07:32 PM
motorcarman's Avatar
Does the engine run?????????????
Restricted performance????
Need more INPUT!!!!!!
A short story of the fault or failure would help.
The AJ26 only has one CMPS on the 'B'bank (left head).
The CKPS is on the engine side in the lower bell housing (near the steering rack).
bob gauff
Bcrary3
Sep 12, 2021 05:41 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
corysansburn
Sep 10, 2015 06:15 AM
TexasCat
Sep 8, 2015 04:36 AM
