Air compressor moisture
Old Apr 10, 2021 | 11:35 AM
equiprx's Avatar
Default Air compressor moisture
I have a machinery shed which housed our central vacuum system and my compressor.
There has always been water in the system.
I have a water separator with particle filter that doesn't seem t do anything.
Every time I open the drain there is water in it.
Not only that but water is making it's way through the hose reel into the tools.
I have been doing a bit of research.
I read that I need a minimum of 20 feet separating the compressor from the outlet.
That is of course impossible but someone suggested using an air conditioner condenser.
Has anyone tried that and how did you go about assembling it in the system.
Did you use a cooling fan and how did you wire it up?
I'm thinking of mounting it relatively flat, is that a problem?
This is an experiment so I can't afford to just waltz in to the dealer and order it.
Any easy suggestions on the easiest way to find one?
Old Apr 10, 2021 | 03:36 PM
pdupler's Avatar
I found that those water separators separate very little. I do a lot a media blasting in restoring old cars (but I leave the body painting to pros with a proper booth). When I first started doing glass bead, I couldn't go very long before the media would just start clogging up from the moisture. Then somebody I was talking with at a local car show suggested I get something called a "TP filter". I asked what's a TP filter and they described a filter element that looked exactly like a roll of toilet paper. After a little research, I found the Motor Guard M-60 (no its not an engine oil filter though it sounds like it). My troubles were over. I just take the element out and dry it in the oven on "warm" setting once in a while, but it seems to be able to absorb A LOT before any moisture gets through. I found that I can go all day for a couple of days but I purchased a spare element so I can switch out and keep blasting with one while the other is drying out.
Docko
Jan 3, 2021 06:25 PM
Wessex
General Tech Help
Dec 29, 2015 04:40 PM
pladyt
General Tech Help
Jul 20, 2010 02:30 PM
JDS
Jul 20, 2010 05:49 AM
lsuneworleans
Jun 30, 2010 04:35 PM
