AJV8 4.2 SC lean codes
Old Nov 19, 2020 | 11:02 AM
Aarcuda's Avatar
i wouldnt think the condition would affect the timing. When mine was lean, it seemed to run pretty strong
Old Nov 26, 2020 | 04:41 AM
melhookv12's Avatar
I had a s type r doing the same thing after i had replaced the engine. ( at a dealer under warranty)
Run the engine, using short term fuelling live data and spray carb cleaner around the engine and you might see the trims change as it draws the extra fuel in. It might only happen on a really hot or cold engine due the the plastics and metals expanding and contracting.
My fault was the top seal from charger to inlet. You couldn't hear the leak but it was drawing in the carb cleaner and richened up the mixture, seen on short term fuelling.
Old Nov 30, 2020 | 01:20 PM
mgrover_sc's Avatar
well basically all dismantled to the sexy sexy core. supercharger is off(got snout rebuilt and 10% pulley), intake manifolds all off, injectors off. some of the gaskets were in a right state. so basically fresh everything, from injectors getting full clean, to fresh gaskets all round. am tempted to do knock sensor/map while am here because i dont wanna have to dig in again
Old Dec 8, 2020 | 04:13 PM
mgrover_sc's Avatar
Bit of an update. After car is back together now its throwing p2101 whenever I floor it. Seems to point to throttle body being damaged while it was out.
Lean code wise now it's like at 20% none stop but that's probably from the throttle body being knackered.
Old Jan 8, 2021 | 03:56 PM
mgrover_sc's Avatar
bit of an update on this, turns out when the throttle body was reinstalled the gasket wasnt fitted properly so it bent, when the throttle plate opened it hit the gasket and am guessing freaked the computer out.
a fresh gasket sorted the issue but the car is torn down again as am chasing the air leak, my passenger valve cover gasket is leaking.
Old Feb 4, 2021 | 02:18 PM
mgrover_sc's Avatar
Bit more on this. The pcv pipe that goes to the throttle housing has oil all around it so I assume its been leaking and as such letting air in. Am going to try change the oring and if not I'll get a replacement.
Old Feb 12, 2021 | 03:21 AM
mgrover_sc's Avatar
Bit more of an update on this. After a good amount of driving in conditions these are now the fuel trims. Which now seems huge but smoke test and squirting wd40 all over the place isn't yielding anything.
Old Feb 12, 2021 | 09:44 AM
  #28
JagV8's Avatar
WD40 seems an odd choice but may work. I'd use a gas not a liquid!! Especially when the liquid failed to work. There are plenty of places a liquid may not reach or may not be dragged into.
What did you do whilst spraying it?
Old Feb 12, 2021 | 10:06 AM
mgrover_sc's Avatar
i was checking short term fuel trims and lambda readings to watch it go hopefully really rich
Old Feb 12, 2021 | 11:38 AM
  #30
JagV8's Avatar
Your best bet would be STFTs but use something that burns easily and is gaseous. Even then you need the leak present (check trims) (e.g. some leaks only occur when moving or when ... well, you get the idea) and to get a bit lucky, plus on many cars some leaks are not where you can easily spray (e.g. EVAP canister piping).
Old Feb 13, 2021 | 08:13 AM
  #31
mgrover_sc's Avatar
Tbf that's the only piping I haven't checked cause it's behind engine and a ballache to get to
Old Feb 14, 2021 | 09:20 PM
  #32
scottjh9's Avatar
2 leaks i found on my str after i pulled the charger were the evap hose where it goes into the induction elbow and the brake booster tube o ring at the elbow
Old Feb 15, 2021 | 03:51 AM
  #33
mgrover_sc's Avatar
how did you confirm the leaks? was it just smoke testing?
Old Feb 15, 2021 | 11:42 AM
  #34
scottjh9's Avatar
no. I always felt i had a minute vac leak because of my stft on both banks but never set a code. When i took the lines off they came off way to easy and i found both sealing o rings hard as a rack. New o rings fixed my fuel trims so i figured that is what is was
Old Feb 15, 2021 | 01:08 PM
  #35
mgrover_sc's Avatar
hmm ill have to check those then. the evap one defo felt like it came off too easy last time i had it off
also to test it, can i just unplug it and block off the hole? if its the cause of the leak it should report rich fuel trims right?
Old Feb 15, 2021 | 04:47 PM
  #36
scottjh9's Avatar
well...i would think blocking the evap inlet would eliminate any possible vac leak there and cause the trims to lean out...the norma connecter should take a little push to seat and lock tightly...aarcuda mentioned changing every suspect o ring for sure and I agree....otherwise it is hit and miss...i do not know the layout of the rover vac hoses, so I cannot tell you much more than trust the short trims
Old Feb 16, 2021 | 02:49 AM
  #37
mgrover_sc's Avatar
i just mean the evap pump isn't critical to the running of the car. i dont wanna go breaking something i shouldnt 😂
Old Feb 16, 2021 | 04:22 PM
  #38
scottjh9's Avatar
oh yeah...correct...but do not plug the line because the gas fumes have to go somewhere
VPinGA
Jan 23, 2025 02:42 PM
Allycat
Oct 24, 2022 05:58 PM
Mohab
Mar 16, 2021 01:50 PM
Rogermgreen
Feb 5, 2020 08:26 AM
Mr_
Sep 13, 2017 10:12 AM
