Aluminium furring
Old Mar 20, 2019 | 04:23 PM
Gerard's Avatar
Default Aluminium furring
Does anyone know how to clean aluminium that has furred up? I am doing up my XJ40 and the gearbox casing has all furred up and is very dull. I would like to clean it while I have it out of the car. Does anyone have ant good tricks for cleaning this?
Old Mar 21, 2019 | 03:41 AM
Presuming you only want to clean the rough casting and not polish the surface, the usual trade method is a wash product containing dilute phosphoric acid applied with a hot or cold pressure washer.
However, any of the "non acid" alloy wheel cleaning products for the DIY market should do the job. I use Sonax Wheel Cleaner.
Spray on, agitate with a brush and hose off.
Old Mar 22, 2019 | 06:30 AM
Gerard's Avatar
Default Aluminium Furring
Thank you, I will give it a try.
Is there anything I can put on it after to prevent the furring starting again?
Regards, Gerard
Old Mar 22, 2019 | 08:31 AM
Autoglym do an Alloy Wheel Protector aerosol. I haven't used it so can't offer an opinion on the effectiveness but it should offer temporary protection. The problem is the transmission casing will always be subject to water spray so If you want a permanent seal to prevent oxidation, an aerosol Clear Coat is probably a better option.
As I recall from my XJ40, the transmission casing is quite a rough finish so once thoroughly cleaned, a clear coat should adhere without any additional preparation.
I took this out to replace a faulty torque convertor. Three weeks later, the transmission front seal failed and I had to do it all over again!
Old Mar 23, 2019 | 05:30 PM
Gerard's Avatar
Thanks again Graham!
Nosferatu
Jul 4, 2013 09:56 PM
Roadhogg
E type ( XK-E )
17
Sep 3, 2012 05:05 PM
fergs03R
Sep 16, 2011 06:22 PM
exexpat
Dec 20, 2010 03:25 PM
willow100
Mar 9, 2009 06:13 PM
