Bluetooth connection resolved
Old Apr 26, 2021 | 04:44 PM
Bill400's Avatar
Default Bluetooth connection resolved
Subject is a 2010 XK but solution may have general applicability:
Bluetooth had been working faithfully but failed to connect.
Cancelled the phone Bluetooth connection to the car but failed to reconnect.
Other items on the most network continued to function, so it wasn't a network problem.
Followed the XK Bluetooth flowchart, suspected BTM or antenna.
Removed and disassembled the BTM, sprayed thoroughly with contact cleaner. Dabbed dry with a clean towel.
Left in sun to bake while I ate lunch. Reassembled and re-installed.
Re-established BT connection, entering the random PIN offered by the vehicle.
All is well!
Works fine, lasts a long time!
PS: The XK is a convertible and I suspected water intrusion, although there were no sure signs.
File Type: pdf
vnewtonXK07
Jan 18, 2023 12:07 AM
Kikevzqz
Sep 30, 2014 09:54 AM
lipper
Dec 9, 2010 11:54 AM
jjf923
Audio/Visual Electronics
Jan 12, 2008 06:00 PM
