Coolant cap leaking
Old Aug 18, 2023 | 09:09 PM
JasonHoselton's Avatar
Default Coolant cap leaking
This is the second cap to leak within a week, could it be the reservoir that is the problem or another part?
File Type: mov
Old Aug 24, 2023 | 03:29 AM
Jason,
NOT a lot of info there, except you are in the US, BIG land mass, just like mine
Give us a clue as to the Beast involved please, so we can help you.
Old Aug 24, 2023 | 05:51 AM
Jason,
Model, year and market specification (your location gives this detail) are essential information when asking technical questions. As you have already posted a coolant hose question in X351 forum, I expect this is the same 2012 XJ 5.0?
From the rate at which the coolant is being forced out, I'll be very surprised if it's not a blown cylinder head gasket or warped cylinder head. A pressure test will reveal any leaks in the cooling system and a compression test will indicate specific cylinder issues.
Please read the guidance for new members ( https://www.jaguarforums.com/forum/n...ned-up-241802/ ) which answers many of the most frequent questions about getting started on the forums.
Old Aug 24, 2023 | 07:08 AM
Originally Posted by GGG
+1
Jason,
yes 2012 XJ 5.0 SC, I replaced the coolant reservoir and bled the system through bleed screw and multiple cycles over the last few days. So far it is looking good and no leaks.
I recently had my upper inlet hose, vacuum hoses, and water pump replaced. I had the cap failure after those repairs and Jaguar tested and said there was nothing causing abnormal pressure (such as head gasket). I’m hoping it was just warped reservoir threads.
Old Aug 24, 2023 | 07:53 AM
Keep a close eye on it. Overheating is a Jaguar V8 engine killer.
Old Aug 25, 2023 | 01:13 AM
Autobroker's Avatar
A very easy way to verify a head gasket leak. The kit is $50 and you can reuse the tester - you just need more dye. https://shop.advanceautoparts.com/p/...500/25961533-P
Guardian
Jul 6, 2021 01:35 AM
jrasner
Mar 2, 2021 09:47 AM
jkallinen
Aug 2, 2016 10:32 AM
Xkr x100
Sep 6, 2015 08:50 AM
newuser
Mar 30, 2012 08:36 AM
