Driver door not locking 2009 XF
Old May 29, 2012 | 03:15 PM
2kry4's Avatar
Default Driver door not locking 2009 XF
Help! My driver door stopped locking with both the remote and interior lock button unless I manually push it in while in the car and door closed. Of course the it won't lock manually if door is open and exiting the car.
Old Jun 2, 2012 | 07:14 AM
meirion1's Avatar
Default Door not locking
I have had this problem on my 2004 xj v8 and traced it to the microswitch in the actuator.I don't know if the same switch is used in the XF but I was unable to obtain the switch itself.
You can buy a new actuator (expensive), an used actuator ( even cheaper) or I found that some used ford actuators (really cheap) have the same microswitch which you can cut out and solder into your actuator.
99xk8guy
Sep 29, 2025 10:51 PM
dsnyder586
Dec 29, 2024 07:39 PM
99xk8guy
May 28, 2024 09:36 PM
GordoCatCar
Jan 2, 2017 01:10 PM
XJsc-guy
Nov 23, 2015 01:56 PM
