Ford tensioners for Jaguar???
Old Jan 4, 2010 | 05:10 PM
  #41
SoTxXjr's Avatar
I have not heard the results of the CSI comparison yet, either, but I used the Ford primary and secondary tensioners and chains and they were a perfect fit in both the '99 AJ26, and now the 2000 AJ27 installed in the '99 car. They seem to be working fine, although I am still working through the compatibility issues with the new engine and have not had it out for a good hard run. I don't suspect they will present a problem.
Old Jan 5, 2010 | 03:07 PM
  #42
broathy09's Avatar
Default Ford tensioners for Jaguar
I gave them my vin number and I am under 80k and he said it would be 96.00 bucks to get it done. Im talking to another certain ford dealer employee about it also. I will find out more when I get back in town next week.
Old Apr 12, 2010 | 03:13 PM
  #43
WhiteXKR's Avatar
Does anyone know if the valve cover gaskets quoted earlier in this thread (see below) also fit the Jaguar 4.0?
_____________________________________________
PART NUMBER DESC QTY LIST PRICE YOUR COST
1 2W9Z-6268-AA BELT - 553 2 47.90 95.80
2 2W9Z-6268-BA BELT - 553 2 20.51 41.02
3 2W9Z-6L266-AA TENSION 557 2 32.55 65.10
4 2W9Z-6K254-BA TENSION 555 1 53.42 53.42
5 2W9Z-6K254-CA TENSION 555 1 59.16 59.16
6 -W500301-S300 SCREW 884 4 1.50 6.00
7 2W9Z-6K297-AB GUIDE 019 2 17.60 35.20
8 2W9Z-6L253-AA TENSION 557 2 21.99 43.98
9 3W4Z-6584-AB GASKET 993 1 51.47 51.47
10 3W4Z-6584-BB GASKET 993 1 51.75 51.75
11 2W9Z-6700-AA SEAL AS 737 1 11.48 11.48
12 2W9Z-6020-AA GASKET 742 1 5.77 5.77
13 2W9Z-6020-BA RING - 871 1 3.80 3.80
Old Apr 12, 2010 | 05:51 PM
  #44
test point's Avatar
Yes, they do.
Old May 3, 2010 | 09:08 PM
  #45
WhiteXKR's Avatar
Just thought I would pass along that I picked up the full Felpro Gasket set (FEL-PRO Part # VS50724R ) for the Lincoln LS, fully compatible with my 2001 XKR for $39.79 from Rockauto.com.
Quality and fit seem excellent. This includes both L & R valve cover gaskets, spark plug seals, and a full set of grommets. Pretty decent deal.
Old Jul 14, 2010 | 12:25 PM
  #46
ysgeye's Avatar
Default 4.0 XJ8 primary chain tensioners
So far, I have seen a lot of info on changing out the secondary chain tensioners. Has anybody done the primary chain tensioners in the DIY fashion?
Particularly, I would like to know if I could just unbolt the old tensioners and put the new ones in their place without loosening the VVT, secondary chain sprocket, taking out the guides, using shims, etc.
If not, I suppose I will have to rent the timing tools off eBay.
Thanks.
Old Jul 14, 2010 | 05:44 PM
  #47
test point's Avatar
Check the XK8/R Forum FAQ sticky:
The tensioner section (alphabetical) has several links to DIY discussions and pictorials.
Old Jul 28, 2010 | 02:05 PM
  #48
tesla4all's Avatar
Sorry, posted something totally unrelated...
Last edited by tesla4all; Jul 28, 2010 at 06:04 PM. Reason: Unrelated to thread subject
paulyling
Mark V - X 420G
Aug 15, 2023 09:33 PM
SD96XJ6L
Jan 12, 2022 04:30 AM
jdzubas
Oct 4, 2015 09:14 AM
Sprayall
Sep 3, 2015 07:49 PM
Harry Dredge
Sep 2, 2015 02:26 PM
