Fuel Pump Driver location
Old Jun 12, 2023 | 07:32 PM
WendellB's Avatar
Default Fuel Pump Driver location
My Jag cranks but won’t start. When I jump the battery to the fuel pump it provides fuel to the rail and will run fine. However, there is no volts at the connector when the ignition is on. Replaced fuel pump, inertia switch, fuel filter and pressure sensor, on the fuel rail. I get a P1338 code, which means the fuel pump driver module is not working or possible something else. I have looked and cannot find the fuel pump driver module! Can anyone help please!
Old Jun 13, 2023 | 12:32 PM
motorcarman's Avatar
Have you looked at the electrical guide?
The guide clearly shows the pump control as part of the RECM. (S2003_STYPE.pdf figure 3.2)
04Xjrsteve
Jan 10, 2025 07:42 AM
Smokey59
Jun 13, 2023 07:15 AM
John Baker
Dec 29, 2017 05:05 AM
plums
General Tech Help
Jan 17, 2016 02:28 AM
jarrod_9427
Mar 4, 2015 06:32 PM
