Fuel pump replacment x type need the fuel line connector remova.l
Old Mar 7, 2017 | 03:24 AM
Hobbo's Avatar
Default Fuel pump replacment x type need the fuel line connector remova.l
Would anyone know where i can get this tool?
Old Mar 7, 2017 | 03:49 AM
There's a reason we ask forum members to add Location details. This is a good example of why we do that:
Attached Thumbnails Fuel pump replacment  x type need the fuel line connector remova.l-location.jpg
Old Mar 7, 2017 | 02:36 PM
motorcarman's Avatar
Location is a good idea. I could list a place to buy something only to find out the OP is on another Continent!!
bob
Old Jan 10, 2023 | 09:03 PM
Diff's Avatar
Not sure which one you need but if there is no squeeze connector then eBay/Amazon has them on line or any car parts store will have the type that slips over the line and pushes in to release the 4 pins that hook over the bump in the fuel line. Our 4.2 uses a 3/8 tool or approx. 9mm equiv. But the line dia inside is 8mm or approx 5/16 or .311 thousands of aninch. This is at motor end so tank end may be the quick squeeze type. Butt the best is still to pull pump relay and run engine till it dies to reduce pressure at the connector you are disassembling first. Rag under, eyes protected when separating joint.
Chris Brister
Sep 30, 2020 10:35 PM
kenatofc
Jun 3, 2017 03:49 PM
BenjF
May 18, 2017 07:50 AM
jagclaude
Jun 24, 2012 05:34 AM
