Headlights don’t work but blinkers do
Old Mar 2, 2023 | 02:07 PM
Melsjag14's Avatar
Default Headlights don’t work but blinkers do
Hello,
I really hope someone can help me. I have a 2014 Jaguar XJL. The headlights on the left side stopped working but the blinkers work. What could be wrong? I tried replacing the bulb but that didn’t work. I want to check the fuse but don’t know what number corresponds to the headlights. If someone can help me with that I would appreciate it as well.
Thank you,
Old Mar 10, 2023 | 12:21 PM
clubairth1's Avatar
Community Influencer
Yes. Remove the front bumper and swap the lights from side to side. Next swap the bulbs from side to side. You could have a bad bulb or a bad ballast.
The bulbs are very difficult to replace if you don't remove the head lamp from the car. Did you do this or did you attempt to do it without removing anything from the car?
Maybe the bulb install was wrong?
Old Mar 16, 2023 | 11:17 AM
Ura's Avatar
Ura
good evening with such a device everything will fall into place, try to start ringing whether the control comes to the headlight
Robert Page
Dec 1, 2025 07:39 AM
T26_SYK
Nov 13, 2021 01:00 AM
yjmcb
Mar 23, 2010 10:08 PM
pkaygee
Exterior
Oct 16, 2009 01:26 AM
Lasso5408
Sep 4, 2009 12:18 PM
