Help navigating XK electrical guide
Old Sep 11, 2019 | 01:42 PM
MurrayG's Avatar
Default Help navigating XK electrical guide
Dear experts. I am learning to navigate the XK electrical guide in order to do a little troubleshooting. What a great resource!
I have a quick question I am hoping an experienced person can help me out with.
First - what does "Cav", as shown below in the connector index section of the electrical guide stand for? I initially though "Cavity" (as in location), but that does not seem right as the same "Cav" number is used with different locations.
I have searched the forums, and found the common Jag acronyms - but "Cav" does not seem to be referenced. I also searched the entire electrical guide, and I see no definition for it. My apologies if it is more obvious than it seems to me.
Thank you all in advance!
Old Sep 11, 2019 | 02:17 PM
motorcarman's Avatar
I would guess cavities or MAX number of pins in the connector. A 28 pin connector might only have 23 pins/wires but 28 cavities?
bob
Old Sep 11, 2019 | 03:10 PM
MurrayG's Avatar
Thanks Bob! You'd think they would make it more obvious in the manual. Your guess seems reasonable. I'll see if I can look up the connector and correlate against the number of wires in it to see if they match the numbers.
All the best -
Old Sep 11, 2019 | 09:28 PM
hafren's Avatar
I would guess cavities or MAX number of pins in the connector. A 28 pin connector might only have 23 pins/wires but 28 cavities?bob
Not a guess you are absolutely correct.
Old Sep 11, 2019 | 10:18 PM
MurrayG's Avatar
Thanks for the confirmation Hafren
Mar 7, 2026 02:29 PM
sevenlima
Aug 14, 2015 04:14 AM
Dom_2014
May 13, 2015 07:22 AM
jagxk82005seneca
Nov 4, 2014 03:48 PM
jimbov8
Jul 10, 2014 06:59 PM
