IDS 118.5
Old Sep 20, 2023 | 05:17 PM
tlindi's Avatar
Default IDS125 setup.exe - from where?
I checked and now I can't find the image links either? Maybe that last update caused some problems?
You do know that SDD contains IDS? If you hook an earlier car up to SDD it will know that and then load IDS?
I entered a 2001 S-Type but did not have a car to try it out on.
SDD V160 in IDS:
So you might want to try it and see what happens?
Here is an IDS 125 image if you don't want to mess around with SDD?
IDS V125
Not interrested about images. I want to install physical device.
1st tests done...
https://archive.org/details/jaguar-ids-125.08-dvd
Old Nov 5, 2024 | 06:51 PM
tlindi's Avatar
could you help and run on elevated cmd prompt command
wmic cpu get Revision
and c:\Program Files\JLR\IDS\Runtime\monitor2k2.exe
And then Launch IDS from inside of SDD.
Do nothing, but copy paste log from monitor2k2
pLease?
Old Nov 5, 2024 | 06:57 PM
tlindi's Avatar
If you are still around, might you want to help to debug issue when IDS can't launch from SDD browser windows (after 118.5), please?
joeleerj
25
Aug 26, 2025 03:21 PM
nebelfuerst
General Tech Help
Jul 29, 2025 05:28 PM
Dandi
General Tech Help
Oct 27, 2022 07:40 AM
balka
Nov 5, 2019 03:52 PM
Lagonia
Jan 12, 2014 07:26 AM
