IDS_SDD Deep Dive - Getting Started
Disconnecting the battery cables and going through the rectification process did not change the results. The "clunk" sound I hear seems to be in the vicinity of the starter, so that will be tomorrow's project. I hope I can access the starter from beneath the car after I jack it up about a foot or so and get some jack stands under the right side.
No machinery or vehicle likes to sit for months. That is especially true for Jaguar.
What is - a "clunk" sound? Is that the starter solenoid? If so, check voltage to the starter on the starter side of the solenoid when energized.
SDD is a primarily a diagnostic tool, so yes, SDD can read diagnostic codes and reset or clear them.
If you are not familiar with SDD, look for a friend or shop who can help.
As MotorCarMan said, try your other key if you have one.
If you still suspect a security issue, and have no other options, you could try the rectification procedure:
Disconnect both battery cables and touch them solidly together for about 90 seconds.
Rectification depletes residual electrical charges and may calm a scrambled electronic brain.
Good luck.
Keep us posted on you progress/solution.
Bill[/QUOTE]
Problem solved. It turns out some critter chewed up the wire that connects the ignition to the solenoid. It was not an issue with the key or the security system. I reconnected the wire and I am now able to start the car and move on to the next dreaded project - the leaking valley hose under the supercharger. Thanks for the help and suggestions.
Steve
Good luck.
Bill[/QUOTE]
Steve
Martyn Musch
Mar 28, 2025 04:21 AM
BLKJAG702
Sep 26, 2020 05:30 PM
trosty
Aug 12, 2015 10:44 AM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
