Jaguar Update of BCM Problems! HELP please
Old Dec 22, 2021 | 09:08 PM
zReeDx's Avatar
Default Jaguar Update of BCM Problems! HELP please
Hey guys,
I have extreme problems after updating the BCM of a Jaguar F-Type.
The customer did not say that a speedometer was installed. After the update has been successfully completed, 13 control units show "incomplete configuration" and many error messages such as ABS / ESP / all-wheel drive / E-Differential and much more appear in the speedometer.
Everything no longer works properly, but the car starts and you can drive it.
Unfortunately, since all control units are already up to date, I can no longer carry out updates.
Can the system be unlocked somehow? Or outsmart?
Has anyone already gained experience how to outsmart the Pathfinder?
The car is from 2017 and therefore only works with pathfinder, no longer SDD.
The stopper is now removed and the update of the bcm was also carried out again, but with the same result.
However, the speedometer shows various errors.
If I could somehow reactivate the update function, the problem should be solved!
Please help!
Old Dec 23, 2021 | 02:50 AM
Welcome to the forums zReeDx,
A reply just so you don't feel you are being ignored.
This situation is dreadful at any time but approaching the holiday period, it must be your worst nightmare. Although many of us use SDD, Pathfinder experience is still rare on the forum. However, we do have a few Dealer Techs and Independents as members so you could get a response to your question in time.
Old Dec 24, 2021 | 08:22 AM
clubairth1's Avatar
Community Influencer
Can you fill us in a bit more??
What does this mean? "The customer did not say that a speedometer was installed."
Cars have had speedometers for decades so I must be miss-understanding what you said??
Also you said "The stopper is now removed"
Again this is a mystery statement? What's a stopper?
Capt. Obvious
Sep 16, 2021 10:01 AM
jtmav
XF (X260)
Jun 5, 2021 10:37 AM
Andi Jaguar G
May 3, 2021 01:45 AM
NickMcCandless
Jan 5, 2018 08:53 PM
Dremorg
Dec 19, 2017 08:31 AM
