Jaguar x type x200 Hi beam not working
Old Oct 12, 2024 | 03:40 AM
Themes1's Avatar
Unhappy Jaguar x type x200 Hi beam not working
My Xtype x200 high beam is not working. checked all the fuses and relays. all are working. changed the Light selector switch still same. replaced the bulbs with new. still both are not working. anyone have any idea about this issue. what should i check??
Old Oct 12, 2024 | 01:29 PM
Thermo's Avatar
Veteran: Navy
Themes1, you left off the last year of your car. Let me know what year your car is and I will look at the diagrams and give you a few checks to do so you can figure out what is wrong. The high beam circuit is not that complicated. Also, if you could, give me a general idaa of where you live (USA, UK, Far east, etc). This may change a few things as there are slight differences in the wiring for 3 different areas that have unique headlight requirements.
Old Oct 12, 2024 | 09:41 PM
Themes1's Avatar
Thank you so much Mate. I am from Australia. Found the issue last night. There is a relay in the cabin fuse box number 15.relay is working fine but contact sparked and not giving proper connection. Cleaned it and put it back. It is x type 2002 x200
Old Oct 13, 2024 | 06:43 AM
Thermo's Avatar
Veteran: Navy
Thermes1, stick around. If you do some looking, you will find lots of useful information. People like me have built up quite the list of "how to fix" stuff for your car. It will make keeping the kitty purring a lot easier. You will also want to learn about the "Thermo'd rear arm". Your car is coming around to needing it. Solves a lot of issues.
Old Oct 13, 2024 | 09:42 AM
motorcarman's Avatar
The X-Type is X400.
Here is a list of model designations from Jaguar.
File Type: pdf
doublekite
Nov 4, 2023 07:20 AM
jagent
Jun 5, 2022 02:18 PM
worzella
Jan 15, 2020 11:20 AM
Defbeat
Sep 26, 2019 12:01 PM
Anchor2
Feb 20, 2014 07:15 AM
