License plate mounting insert
Old Feb 26, 2023 | 10:36 AM
Calab's Avatar
Talking License plate mounting insert
Hey all!
I just uploaded an STL file to Thingiverse.com for a license plate mounting insert. This is the little plastic piece that clips into the oval hole where you mount your license plate.
My 1990 XJ-6 had no easy way to fasten a license plate to the trunk. I could use a nut and bolt, but holding the nut in place while inserting a bolt was difficult. I had ended up using some wire to temporarily mount the plate.
I designed a 3D printed insert that would just snap into place and take a normal license plate screw. I just mounted my plate a few minutes ago and it's on there securely.
You can find the STL file to print your own here: License Plate Insert at Thingiverse
Old Feb 27, 2023 | 11:22 AM
cdma's Avatar
Thanks for this. Don't need them for the rear but it appears that New Mexico will require front plates now so may need them for the front. When I repainted my bumper I had them fill in all the holes so this should be interesting
luvinmyjagxf
Nov 20, 2017 10:00 AM
UCFGrad
Aug 27, 2017 07:50 PM
Old Radar
Apr 19, 2017 06:53 AM
Kewpie
Feb 13, 2016 08:55 AM
svahle
Sep 30, 2011 09:26 AM
