Module Experts
Old Mar 9, 2018 | 08:23 AM
tailfin joe's Avatar
Default Module Experts
Hi has anyone used Module Experts in Jacksonville Florida ?? I have been working on a Friends 2005 X Type originally he went to the local Jag dealer because the voltage regulator was causing a parasitic drain on the battery the voltage regulator is part of of the ECM and yes he needed a new ECM cost 2K which I understand Module Experts said they could fix the problem rebuilt ECM 637.00 have had nothing but problems this the 3rd attempt to correct the problem and yes 3 months latter I have a car that doesn't run Gear Box Fault = no crank now cranks but doesn't start , had the instrament cluster reflashed as well as the key and yes I am a retired auto tech and used both of my Pro Autel and Launch scanners which are bidirectional can't find any problems , don't use them!!! any feedback would be helpful thanks Joe
Old Mar 9, 2018 | 05:35 PM
abonano's Avatar
Joe, you need to find someone local that has access to legit SDD or IDS programming with a legit cable (VCM preferred) to sort out your issues.
PCM, TCM, PATS, etc. all need to find harmony and sync together or no dice. You can't simply replace a ECM and expect all the other modules to recognize it.
Just my $0.02
Old Mar 10, 2018 | 06:44 AM
Your Right , but all my modules do line up , they said that they used a 3rd party to repair my ecm , I do have the capability of using my J2534 to reflash the modules but the problem lies in the software they used to repair ecm the moral of the story is"" the sweetness of low price is soon forgotten " I tried to save someone money just wondering who else has used Module Experts to repair there Jag and there feedback thanks Joe
Old Sep 26, 2019 | 07:48 PM
Pmorphis's Avatar
Default Module experts
Really had a horrible experience dealing with those people. Told me the main chip was fried in my ecu and wanted $999.00 for a rebuilt one. Anybody knows if the main chip is fried the car won’t run. My jag ran just not good all the time
Old Sep 26, 2019 | 11:22 PM
abonano's Avatar
You need to give more background and why you think it's your ECU
Old Sep 27, 2019 | 02:23 AM
..... they said that they used a 3rd party to repair my ecm .....
Sounds like you got the monkey when you needed to speak directly to the organ grinder.
Old Sep 27, 2019 | 07:12 AM
I ended taking a chance and bought a used ecm from a local salvage yard , made sure all the numbers were the same as the original and my problems were solved !! and that was almost a year ago but I was out 600.00 plus all the agarvation I had to go through Don't USE Module Experts !!!!!!
Jagman1984
68
Jan 31, 2025 02:26 AM
steve4ltr
Nov 11, 2019 01:55 PM
BradsJag
Sep 13, 2017 01:32 AM
NLXTypeOwner
Nov 21, 2013 05:29 AM
