Need guidance for a coolant leak behind intake
Old Apr 27, 2019 | 12:50 PM
Mike 8897's Avatar
Default Need guidance for a coolant leak behind intake
I'm trying to repair my xf portfolio. Rodents got into my engine bay and I have a coolant leak behind intake. It's either the pipe that connects the heads or one of two hoses connected to the pipe. My problem ? I can't get the wiring harness out of the way to get access . I tried everything . The plastic cover unclips but you can't unhinge it enough to get the cover off. If I was able to remove the cover I possible could have enough room to get back there. I do not want to remove intake. Please anyone who has done this repair let me know procedure and steps to do repairn
Old Apr 27, 2019 | 01:44 PM
I've previously moved several other posts from you on this same topic scattered across the forums.
READ MY REPLY (see post #2 in this thread link) AND FOLLOW THE ADVICE BEFORE YOU POST AGAIN:
https://www.jaguarforums.com/forum/x...tfolio-216774/
THREAD CLOSED
Mike 8897
Apr 23, 2019 09:47 AM
EsRay
16
Oct 8, 2018 10:05 AM
afterburner1
Feb 12, 2015 09:41 PM
MI6
Jun 19, 2008 11:35 PM
