OBDII Code Scanners ** Member Approved **
Old Dec 17, 2013 | 02:40 AM
  #361
JagV8's Avatar
Does it do ABS on your car? It's expensive if it doesn't.
All tools should read P1111 but only a few will also say it's not a fault.
Old Dec 17, 2013 | 05:35 PM
  #362
BoxxMann's Avatar
Yes - reads ABS. I cross referenced the P1111 code against one of the downloads here to know that it's not a "real" code.
Old Dec 18, 2013 | 06:09 AM
  #363
JagV8's Avatar
That's good news.
Old Dec 29, 2013 | 11:43 AM
  #364
Roger95's Avatar
I have ONE question about my '95 XJS and my '96 XJ6 (X300) Vanden Plas:
Is the ONLY WAY to "reset/orient" the ECU to O2 sensors and Throttle Position Sensor (reset throttle angle) is to use a factory Jaguar IDS scan tool? I think "yes" and would like confirmation.
Thank you,
Roger
Old Dec 30, 2013 | 08:13 AM
  #365
BoxxMann's Avatar
That's good news.
My apologies. I have checked to see if it reads ABS codes on the Jag and it does not - I gave you bad information. It will read the manufacturer codes but not the Jag's ABS codes - or at lease from what I can see.
Old Dec 31, 2013 | 04:38 AM
  #366
jimgoose's Avatar
The ELM327 Bluetooth unit works fine on a 1999 S-Type with Touchscan PC software:
http://www.obdsoftware.net/touchscaninfo.aspx
Happy New Year!
Old Dec 31, 2013 | 06:33 AM
  #367
JagV8's Avatar
Thank you,
Roger
I hope someone wil say (but for later cars generally they just sort themselves out i.e. nothing needed, just change the parts).
If you get no replies, try each of the appropriate forums.
Old Jan 29, 2014 | 08:20 PM
  #368
rcode's Avatar
Does the etc... include adaptive cruise control? Very important detail.
rcode
Old Feb 11, 2014 | 09:58 AM
  #369
jagtime's Avatar
Hello to all can someone tell me what diagnostic scanner to buy for my x-type 2001 2.5 and also which abs scanner to buy cheers everyone from jagtime
Old Mar 3, 2014 | 11:52 AM
  #370
DRettaler's Avatar
Default Tester
Just wondering if there are any updates to this. It's has been a while and I'm looking for a code reader that does more then just obd2.
Looking to read all codes on 97xk8
Old Mar 4, 2014 | 12:02 AM
  #371
H20boy's Avatar
Hello all new posters! I know 13 pages is quite a bit to read, but all of the scanner information in the first post of this thread is still very current. That list, among individual threads started specifically to address a unique situation, I would consider a great resource and give you some confidence in selecting a suitable device. DR, the responses throughout this thread addresses those equipment options that do read more than JUST the minimum required engine and transmission codes.
good luck in your search!
Old Mar 23, 2014 | 11:43 AM
  #372
marcgr's Avatar
BAFX scanner from Amazon, $23.99 ; theoretically ELM327 compatible.
Torque Pro app for Android, $4.99
Works great on my 2006 XKR for engine codes. Cannot read any ABS / DSC / Chassis codes (or if it does, I cannot figure out how).
Engine needs to be turned on for app to connect to the OBD unit.
Old Apr 15, 2014 | 10:18 PM
  #373
Chuck Schexnayder's Avatar
I purchased my OBDII scanner from Sears, and although it is a Craftsman, model # 87702, it is in fact an INNOVA 3100g. Reads all the OBDII codes and Freeze frame info. Also does the ABS scan deal, but haven't had a chance to check that part out. Kept gettng "Check rear lights" warning and "Check Engine" warning lights. Rear light problem was a bad Brake Light Switch, which when replaced also fixed the cruise control. Check Engine was a bad Mass Air Flow Sensor. Replaced that also and so far no more lights.
Use is on a 2005 XK8 and XJ8L.
Very satisfied so far.........
Old Apr 16, 2014 | 01:58 AM
  #374
Originally Posted by Chuck Schexnayder
I purchased my OBDII scanner from Sears, and although it is a Craftsman, model # 87702, it is in fact an INNOVA 3100g. ........ Very satisfied so far.........
Welcome to the forum Chuck,
Good to hear you have got your DTC's resolved using the Innova 3100g.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Apr 16, 2014 | 09:19 AM
  #375
H20boy's Avatar
Original post with approved/disapproved scanners are current as of today.
Old May 8, 2014 | 12:22 PM
  #376
sfischthal's Avatar
Thumbs down Scantool advice
Can someone recommend a scantool for the 1995 XJS V12? Please only recommend if you have used it yourself... thanks
sy at syf0@aol.com:i con_lol::i con_lol:
Old May 21, 2014 | 08:09 AM
  #377
bigdhenderson's Avatar
ELM327 with Torque Pro works on my 2010 XKR. However, I have found some glitches that caused some panic at first. After disconnecting it and restarting the car then plugging it back in things are back to normal. Best practice is to remove when done and reinstall after engine is started again. Not something that can be left plugged in all the time
Old May 23, 2014 | 11:50 PM
  #378
DKurtti's Avatar
Launch Creader VIII with 2002 X-type. Reads engine, transmission, ABS, and SRS. Lots of live data, from the usual engine stuff to transmission- gear selected, current gear ratio, temp, shift solenoid feedback. ABS- individual wheel speed, brake hydraulic pressure, steering wheel angle, priming valve. SRS- seat occupancy, relays, just to name a few. Supports 1994-2014 XJ, 2008-2014 XF, 1997-2015 XK, 2014 F type, 1999-2008 S type, 2001-2009 X type. I've only used on X-type, but I could look up a particular model to see what datastreams are supported if any one has questions. Updates are free. Attached some screen shots.
Attached Thumbnails OBDII Code Scanners ** Member Approved **-dsc_0088.jpg   OBDII Code Scanners ** Member Approved **-dsc_0100.jpg   OBDII Code Scanners ** Member Approved **-dsc_0091.jpg   OBDII Code Scanners ** Member Approved **-dsc_0097.jpg
Old May 24, 2014 | 04:52 AM
  #379
JagV8's Avatar
What does it cost with those features?
Old May 24, 2014 | 05:28 AM
  #380
DKurtti's Avatar
Paid $215USD shipped.
